What does this wire do?
Hi guys,
I am trying to find out what a particular wire does.
My Wiring diagram only says this wire goes from the ECU to the 'Starter Circuit'........
Would this wire from the ECU run a relay prior to the starter motor for example? Is it normal for modern cars to have the ECU controlling the starter?
Any help appreciated
- tim_81coupe
More than likely its a tell-tale for the starter motor. This wire lets the ECU know the car is cranking, and adjusts settings to help starting, such as opening the injectors and widening the throttle bypass valve. You'll want it or the car will be really hard to start.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
- Outback bloke
- BaronVonChickenPants
- Outback bloke
