TT has taken on a new life .....
legacytt
Post by legacytt » Tue Jan 24, 2006 1:23 pm
After a lttle work the transformation has occurred and what was once the perfect sleeper road cruising wagon is now the ultimate offroad voyager. Apologies for the dark photo.
It started life as a Heritage and was converted to TT around 3 years ago. It now has a 3 inch lift, 16 inch Forester GT Rims and 215/70 BFG AT's finish it off nicely. Next is a Lib dual range with L series low as the Aus Spec RS turbo gearing in it now is a bit too tall.
Gen 1 Legacy GT 3inch lift and 28's
wrx_nut
Post by wrx_nut » Tue Jan 24, 2006 2:29 pm
nice ride mate... were you in lorne about 2 weeks ago.. or near lorne in victoria?
i swear i saw a lifted soob like that!
85' Touring Wagon, EA82T, 3" Lift, 27's, RS intercooler
90' Brumby (B&S Project!) still cutting rust :P
Fatz
Post by Fatz » Tue Jan 24, 2006 2:31 pm
truly amazing
bluesteel
Post by bluesteel » Tue Jan 24, 2006 2:39 pm
nice work ian...
shame you wont be there when i come through on the weekend :?
legacytt
TT Lift
Post by legacytt » Tue Jan 24, 2006 2:47 pm
Sorry wasn't in Lorne, has only been in Tas in this form so far. Keen to catch up with all the Tassie boys for an offroad trip, now that I can keep up with you without tearing parts off the underside. Is the monster going yet Johnny?
vincentvega
Post by vincentvega » Tue Jan 24, 2006 4:44 pm
kickas Ian. nice work
what suspension you running?
bluesteel
Post by bluesteel » Tue Jan 24, 2006 4:46 pm
:oops: umm...
nearly, been a bit slack lately and havin a few issues with the twagon that ive had to sort out
cant be too far off now tho
Fatz
Post by Fatz » Tue Jan 24, 2006 4:48 pm
lorne?? launnie in tas u mean?
suspension is raised king springs(sorry to steal ya heat ian) :wink:
smoov
Post by smoov » Tue Jan 24, 2006 5:44 pm
pfffwoooaaarrrr!!!!!
why not an auto, may i ask??
1998 Subaru Legacy GTB
seagull
Post by seagull » Tue Jan 24, 2006 7:20 pm
Yes Ian please give us a run down on the springs struts you are using .
did you just use a 75mm body lift not a sring tower lift as well ?
did you purchase the body lift or make it your self .
I am doing the same to my wagon in Perth , so interested in your build up .
Looks the part from were I am sitting .
seagull
BaronVonChickenPants
Post by BaronVonChickenPants » Tue Jan 24, 2006 7:32 pm
Looks very very nice, looks like you'll have plenty of fun with it.
Amy reckons it needs bigger wheels and tyres, it's entirely possible I'm a bad influence :twisted:
Jordan.
MUDRAT
Post by MUDRAT » Tue Jan 24, 2006 9:25 pm
That really is a masterpiece. Well done.
Monster Subaru sold to a good home!! Still a Subaru owner. Will try stay in the Ausubaru loop. Sorry :cool:
legacytt
Lib
Post by legacytt » Wed Jan 25, 2006 7:37 am
Thanks for all the positive comments folks. It is a 3 inch lift, Outback Struts, Kings raised springs and Outback rear swing arm mounts. Car used to be auto, so if the low range manual won't tow a heavy trailer in the bush I will revert to that again.
BRUMBERTY
Post by BRUMBERTY » Wed Jan 25, 2006 8:26 am
Clap Clap Clap.
Ian, it looks fantastic.
To quote a famous Aussie actor...
"You've seen it, you've heard it........when do we go for a ride??"
How about Friendly Beaches or Central Highlands???
Isn't there a kick arse track up the Western Tiers from around Cressy?
I will be calling.
1989 Subaru WonderBrumby II
Suby Wan Kenobi
Post by Suby Wan Kenobi » Wed Jan 25, 2006 11:39 am
Looks a very neat package, the TTs work nice offroad with an auto if you havent considered it yet.
seagull
Post by seagull » Sat Feb 11, 2006 12:59 am
Is this running out back kings springs or liberty kings on the front ?
any one ? I am going shopping for these sat , seagull
vincentvega
Post by vincentvega » Sat Feb 11, 2006 7:18 am
early outback front and rear struts, with outback springs. Ian's are raised king springs, but you should choose between raised and standard height based on how high you need the front of your car..
(im not sure what parts you have used elsewhere)
aspro
Post by aspro » Sat Feb 11, 2006 3:46 pm
Id be proud to say i owned that.... real head turner. Well done.
vidler
Post by vidler » Sat Feb 11, 2006 4:47 pm
nearly makes me want 2 sell my L-series and start a project like that. very impressive
legacytt
TT
Post by legacytt » Tue Feb 14, 2006 2:04 pm
It certainly has been turning heads and has received a lot of positve comments. Had a Landcruiser owner look under it and exclaim "It's got more clearance than the 'Cruiser, very inspirational, I want one"
I have put quite a few k's on it and am very impressed with the overall package. I have a Lib dual range, L series low range gears and a 4.11 front diff lined up on the bench. Now to merge them all together. It is definately geared far too tall as it is so this setup should make it do the job.
