alternator issues
alternator issues
Post by D3V1L » Mon May 12, 2008 6:22 pm
today the ob started doin some strange things
apon startup the battery light comes on and so does the brake light (even when park brake disengaged)
it will stay on till i rev the titties off the motor then it goes away
ive been told its probably the regulator on the back which costs around $60 to replace
just after a second opinion before i pull the thing apart as i dont have the money to replace the whole alternator yet
dave
Post by Gannon » Mon May 12, 2008 8:50 pm
Best thing to do is grab yourself a multimeter and check your battery voltage.
With the engine running (at idle should be fine) it should be between 13.2 and 14.4V
If it is outside this range, it could be quite possibly the regulator
Post by D3V1L » Mon May 12, 2008 9:36 pm
i already know its not charging at idle....its non operational untill i rev the balls off the motor...then it starts working
dave
Post by Gannon » Mon May 12, 2008 10:06 pm
Oh ok
It could be the regulator, or it could be the alternator. Its hard to test without dismantling the alternator and testing it seperately
Post by D3V1L » Mon May 12, 2008 10:47 pm
yet looks like ill have to check when i get back from work
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue May 13, 2008 10:38 pm
It will be your regulator, had the same thing happen on a few different cars now, usually they dont drop out completely like yours initially.
The long road ahead
90brumby
Post by 90brumby » Wed May 14, 2008 9:36 pm
dave i got ur old lib alternator here if u wanna try that n if it wrks or fits u can ave it
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Return to “Trouble Shooting”
