Aftermarket ECUs??
SuBaRiNo
Aftermarket ECUs??
Post by SuBaRiNo » Sat Nov 24, 2007 11:45 pm
Im begining to explore this angle now that i have the Supercharger installed.
Any particular brand/make/model aftermarket computer be best suited to a supercharger... i currently know NOTHING about these but this is where i want to begin my research.
Dave
seagull
Post by seagull » Sat Nov 24, 2007 11:56 pm
Dave , my mates are buying the unit from south africa , they have very good quality & you can get it in part for or made up .I get the email adress from Simon when he comes over .
All the Vw boys are running these with ej22 , super charge & turbo conversions
BrennyV
Post by BrennyV » Sun Nov 25, 2007 10:58 am
any 'piggy back' should do the trick.
greddy/trust e manage
haltech interceptor
wolf3d
Hunter S. Thompson
Post by Gannon » Sun Nov 25, 2007 11:28 am
E-manage are supposed to be good.
If i go piggy back on my EA82T, i'll use emanage
BrennyV
Post by BrennyV » Sun Nov 25, 2007 11:38 am
emanage is a good all round piggyback. keep in mind tho if you want a tune ring around get the prices and find what shops support what ecu's.
give mic @ overboost a call mabye.
Hunter S. Thompson
mattl200
Post by mattl200 » Sun Nov 25, 2007 8:36 pm
check out the megasquirt dave thay come in kit form makes them cheeper but check if a local shop knows how to tune them first
and all the software and source code is open source
http://www.megasquirt.info/
not the easyest option though
Post by D3V1L » Sun Nov 25, 2007 9:47 pm
i aggre with the emanage piggy back, reliable and have a reputation
but as brendan said...have to ring around and ask about tuning..can be a problem "sometimes"
dave
subanator
Post by subanator » Mon Nov 26, 2007 11:42 pm
A brother of a bloke at work got a group build on Megasquirt 2 for his turbo Rodeo, he was real happy with it. Can do on road loop tuning with it, can change point mapping and scaling real simply also, but may need a decent A/F ratio meter to calibrate. This is how they did it.
I would pay a visit to Tim at Sik Em Wrex in Mandurah, he installs Microtech, a big plus is they are well supported in WA and used extensively, and he has it dyno tuned as well and guarantees his work too. But it will cost as per any installation and tuning.
PeeJay
Post by PeeJay » Tue Nov 27, 2007 5:35 pm
I thought Megasquirt don't work with EJ Subarus unless you change the cam/crank angle sensor?
Outback bloke
Post by Outback bloke » Tue Nov 27, 2007 7:58 pm
http://microtechefi.com/
I have used these for years. Note that they aren't a top of the range ecu but very good value for money.
SuBaRiNo
Post by SuBaRiNo » Tue Nov 27, 2007 9:01 pm
I will check them out... thanks guys
Dave
schultzie
Post by schultzie » Thu Nov 29, 2007 8:08 pm
wolf 3d? the new v5 is awesom from all accounts... ?
i have no problems with my v4+ it is fully sik.. .
L-series Ea82t, WAIC+BOV 1Bar, 15's, 5sp dr, WOLF3D V4+, =D
