Hatch Supercharger progress
Just an update... rain has held me back a little today... plus i went on to change some brake parts.
However... bracket is now painted and fitted, Supercharger is mounted. Im still waiting on my belt which i prey fits. The pics below might make the bracket make more sence.
Dave
Dave
- Captain Obvious
wow there will be alot of pipe work for the intake wont there???
Tim and I have already compared injector hats... way different.
Dave
Dave
Air intake is roughly done.. but by all means not the final product.
I was let down with the belt again... have to wait till monday now.
Dave
Dave
Ok... got a belt today and was able to run it... had some slight belt problems which are now pretty much sorted.
Powered up the clutch to find the car hunts for idle constantly while the charger is on.... i guess this is to be expected.
My intake pipes are not up for the challenge and they began to expand up and down (A LOT) like it was a heart beating... looked kinda cool... but they will blow.
Gave the car a little rev to find pretty much every hose join after the Super Charger blew apart... wasn't expecting that much pressure there. Also found the belt would slip at higher RPM so had to tighten that right up... more than you usually would.
Still not sure how im going to wire this thing... im not sure if it would ever idle properly with the charger powered up. Perhaps the ECU would eventually sort it out but as soon as i switched it off it would be confused again.
Sorta thinking about making it off when at idle and activate it when u depress the accelerator a little... and of course on and ON/OFF switch.
So getting there... the thing sounds soo cool... like it growling... scares me a little actually... i have been too scared to attempt to drive it or even rev it above a few thousand RPM.
Need new hoses and hardcore clamps and will try it again.
Dave
Dave
im scared....Subafury wrote:its ok to be a little scared of it dave. so get your courage togther and unleash the beast!!!
correct to how u said u were gonna wire it up OFF at idle then on at bout 2grand or somethin
if u have it on at idle it will ova boost n if u have a gauge it will shoot right round back into the vacum part of the guage
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Don't let Hatchie hear u call it a coupe.El_Freddo wrote: Another nice piece of engineering there for the coupe...
Dave
bahahah your a funny one tristan.....thats total bull ****
my dad has supercharged a number of cars in the past and no sc turning off (99% of them do not turn off ever only the toyota one does this via an aircon type clutch), no blow off valvue, no nothing except a clean supercharer( several where trialed with intercoolers but did absoluyttley nothing). At idle they remained the same...idled nicely...but still maintained boost...no problems.
if your interrested in what knowledge i got then ring me and ill happily talk...but im not gonna say anything on here due to the huge range in opinions around
but the cars that he did supercharge where a HK GTS monaro first engine was a 251 with a sc bolted on top produced in excess of 600hp, later going to a fuel injected 308 with a vortec supercharger producing 578hp
2nd car was a standard supercharged v6 commonwhore VT in nature, removed stock sc and put on a yella terra roots type supercharger producing 9 pounds boost and produced 343hp on stock internals
3rd car he supercharged was an old torana with a heavily worked 454 v8 with a huge powerdyne supercharger and twin holley 600cfu carbies producing over 600 hp again.
My old boy used to be a r and d engineer for cappa superchargers over east ...but ill sotp there...ha!!
it will be vastly diffrent on boxer engines but the main principals remain the same
peace out
dave
peace out
dave
90brumby wrote:correct to how u said u were gonna wire it up OFF at idle then on at bout 2grand or somethin
Dave i think i need you to come over and check this thing out... im seriously scared of this thing.
How much pressure should i be expecting after the super charger... seams the more i rev it the more pressure... i thought the pressure was meant to stay the same no matter what RPM.
Dave
Dave
