Halogen Headlight upgrade?? ea81
SuBaRiNo
Post by SuBaRiNo » Sat Sep 01, 2007 11:38 pm
ok great... now same test with head lights on and high beam.
Dave
subaruby
Post by subaruby » Sat Sep 01, 2007 11:41 pm
latest observation, with wiring as per your diagram. connect battery up and low beams on with dash switch set to off, turn lights on at switch on dash, lights remain on but can switch high beams on at off at dash.
if i have the light switch off on the dash with low beams automatically on i can switch high beams on but not off?
Suspension lift.
SuBaRiNo
Post by SuBaRiNo » Sat Sep 01, 2007 11:41 pm
actually have you got MSN mate??
Dave
subaruby
Post by subaruby » Sat Sep 01, 2007 11:45 pm
ok lights on with high beam
red/white 0v
red/blue 11.7v
red/black 0v
Suspension lift.
subaruby
Post by subaruby » Sat Sep 01, 2007 11:48 pm
yes do have msn
Suspension lift.
subaruby
Post by subaruby » Sat Sep 01, 2007 11:50 pm
Suspension lift.
subaruby
Post by subaruby » Sun Sep 02, 2007 1:06 am
managed to sort it out will post again 2morrow
zzzzzzzzzzzzz
Suspension lift.
subaruby
Post by subaruby » Sun Sep 02, 2007 1:09 am
thanks for all your help Subarino
will have to buy u a beer :D
Suspension lift.
subaruby
Post by subaruby » Sun Sep 02, 2007 2:13 pm
turns out i didn't quite have it sorted. Last night had it working, so left it till this morning to solder everything up. After soldering checked again, and works except once u turn high beam on u can't turn it off. So double checked all conections and everything was ok, this time high beam worked, then it didn't then it did. So decided to see if my spotties still worked, no go so i hope the problem is linked to the spotties somehow, maybe a fuse. Anyway will have to leave it till tomorrow night.
Suspension lift.
BRUMBERTY
Post by BRUMBERTY » Sun Sep 02, 2007 6:37 pm
This is exactly where I am up to as well,
with chattering relays when I put the power wires on.
It is not happy.
Do you mind if we keep it here and public so we can all learn from it?
Are you online tomorrow arvo Dave?
Cheers'
Matt
1989 Subaru WonderBrumby II
subaruby
Post by subaruby » Sun Sep 02, 2007 10:15 pm
managed to get everything working, spotties, high beam low beam etc. Still have an intermitant faulty when sometimes i turn the high beams off at the switch they will still stay on. If you then pull the indicator stalk towards u like when "flashing" your high beams at someone and back to low beam it will turn them off. then you can switch high beam on and of normally for a while but then it will fail again.????????????????
Suspension lift.
SuBaRiNo
Post by SuBaRiNo » Sun Sep 02, 2007 10:16 pm
Im only usually on at nights fellas. Weird that my wiring diagram works spot on with my car... i have double and tripple checked it... more than happy to help people work on getting theres sorted though. I should be ablke to modify my diagram based on any wiring... all i need is to know is what the state of each factory head light wire does when the headlights are OFF, ON low beam and ON high beam.
Dave
Post by El_Freddo » Mon Sep 03, 2007 5:13 pm
subaruby wrote:managed to get everything working, spotties, high beam low beam etc. Still have an intermitant faulty when sometimes i turn the high beams off at the switch they will still stay on. If you then pull the indicator stalk towards u like when "flashing" your high beams at someone and back to low beam it will turn them off. then you can switch high beam on and of normally for a while but then it will fail again.????????????????
I had this same problem with my driving lights on the L series. It turned out to be either a dodgy relay or that i had the two relays (same brand/model) mounted side by side, i think something in one relay that's used to trigger power to the lights was holding the other one's switch mechanism closed all the time when it happened - it only happened randomly and to turn off the offending driving light i had to get out, pop the bonnet and tap the relay or wiggle a wire. Note: no wires were crossed or touching eachother and normal operation of the lights would continue til this thing would randomly happen again...
With the different brand of relay in place of the maybe dodgy one i have not had the same problem appear... yet.
Hope this is of some value, if you have the relays mounted side by side try mounting them separated by a cm or something, or stick a different brand of relay in place of one (i'd imagine different brands would have a different layout internally).
subaruby
Post by subaruby » Tue Sep 04, 2007 10:00 pm
ok latest update, think i have finally got it working. Tried a new relay, but no difference, so thought it must be getting some "feedback" into the relay. So put in a rectifer diode and seems to have fixed it. Not sure how or why though.
Thanks for the tip El freddo, they are different relays but are very close together, so will move them apart anyway
Suspension lift.
Post by El_Freddo » Wed Sep 05, 2007 10:12 am
I'm glad the tip was or is useful.
subaruby
Post by subaruby » Mon Sep 17, 2007 8:34 pm
El-freddos tip kind of made sense to me as every time i pulled apart the wiring and change something it would work and then whe i put it back together (and the relays side by side) it would go dodgy again. Anyway the relays are seperated now and so far its working ok?
To anyone who is considering the upgrade, its highly recommended, massive increase in light output and quality. Previously when turning on my spotties there was a huge difference, now i can hardly tell if they are on.
Thanks to all for the helpfull comments.
Suspension lift.
SuBaRiNo
Post by SuBaRiNo » Mon Sep 17, 2007 8:37 pm
ONE thing has anoyed me about this upgrade... now my spotlights seam DIM so i will need to upgrade them or give the wiring for them some attention too.
Dave
Post by El_Freddo » Tue Sep 18, 2007 11:54 am
SuBaRiNo wrote:ONE thing has anoyed me about this upgrade... now my spotlights seam DIM so i will need to upgrade them or give the wiring for them some attention too.
Dave
Hehehe... its a vicious cycle... enjoy!
Wilbur
Post by Wilbur » Tue Sep 18, 2007 3:24 pm
Dave
HID the spotties !!! :mrgreen:
BRUMBERTY
Post by BRUMBERTY » Tue Sep 18, 2007 3:53 pm
Lightning_Silver_RX wrote:HID the spotties !!! :mrgreen:
Thats what I am doing.
Best of both worlds I think.
