signs your clutch is on it way!
Captain Obvious
Post by Captain Obvious » Sun Aug 05, 2007 8:15 pm
went for a run down to rainbow beach today and coming back off the beach at freshwater camp ground (still had hard tyres) i had to back off a little and cause i did the revs droped so a faned the clutch and gave it a boot and the revs went around to 5000rpm and i let the smoke out of the clutch!! stinks real bad that stuff!
so i let the car idle for 5 while i let the tyres down and it was ok after that, but it wont last much longer :(
Ben
Post by Ben » Sun Aug 05, 2007 10:20 pm
Like anything, once the smoke is out, no going to be the same again...
Seeing as you'll have the engine out, you may as well whack a bigger turbo on while your there!
Please watch before posting!
Chris_Rogers
Post by Chris_Rogers » Sun Aug 05, 2007 10:51 pm
and a rebuild as well :)
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
Post by AndrewT » Mon Aug 06, 2007 12:43 am
Never a nice smell hehe.
Lemme guess...you had to downgrade to a push-type clutch to allow you to run the dual range gearbox. Turbo's really need a propper turbo clutch, a pull-type. The NA ones can only last so long even with a heavy duty pressure plate :(
Mine's still holding up after a year of punishment but I'm sure it will slip soon!
Captain Obvious
Post by Captain Obvious » Mon Aug 06, 2007 8:52 pm
yeah was like that when i got the car, the turbos to eat clutchs offroad but its better that then gearboxs every week!!!
and yess there is many things i would like to do while its all apart but $$$$ dont go far enough :((
