so i let the car idle for 5 while i let the tyres down and it was ok after that, but it wont last much longer
signs your clutch is on it way!
- Captain Obvious
went for a run down to rainbow beach today and coming back off the beach at freshwater camp ground (still had hard tyres) i had to back off a little and cause i did the revs droped so a faned the clutch and gave it a boot and the revs went around to 5000rpm and i let the smoke out of the clutch!! stinks real bad that stuff!
- Chris_Rogers
Never a nice smell hehe.
Lemme guess...you had to downgrade to a push-type clutch to allow you to run the dual range gearbox. Turbo's really need a propper turbo clutch, a pull-type. The NA ones can only last so long even with a heavy duty pressure plate
Mine's still holding up after a year of punishment but I'm sure it will slip soon!
EZ30 L series - Monsterwagon
- Captain Obvious
yeah was like that when i got the car, the turbos to eat clutchs offroad but its better that then gearboxs every week!!!
and yess there is many things i would like to do while its all apart but $$$$ dont go far enough
