EA82T - EA82T what to replace?
Ok, this will test ya’s (sorry if its in the wrong section)
When the new engine gets here (sorry for those of you that do not know we are talking about 1 of the only low km Jap Import EA82T) and before it goes in the engine bay and bolted up for a thrashing this is what I am looking at replacing.
Ready – DEAP BREATH – here we go…
- Timing Belts.
- Front Crank seal.
- Cam Seal (x2).
- Cam O ring seal (x2).
- Oil Pump Kit.
- Gear and Rotor set.
- Water Gaskets, including water bypass hose and o ring.
- Timing belt Idler pulley bearing.
- Rear crank seal.
- Oil separator plate gasket.
- Thermostat and thermostat gasket.
In addition to this I will also be checking, and replacing if required, the following…
- Manifold bypass hoses - both RHS and LHS.
- Turbo hoses – both upper and lower.
- Radiator hoses – both top and bottom.
- Heat tab on engine block (they tell me there is 1 on there).
- Might look at cold air induction, however still like the idea of snorkel
The basic service is a given…
- Air, fuel and oil filters
- Spark plugs.
- New oil, and radiator coolant, plus distiller water.
- To the WA regulars I MIGHT even replace my battery – thinking = lol
- I was thinking about the clutch however, I have not had any issues with the current set up and she is showing no signs of slipping?
Any suggestions on this 1?
PHEW… Is there anything else you would suggest/recommend/I might have missed???
Thanks for any input.
- Timing Belts.
- Front Crank seal.
- Cam Seal (x2).
- Oil Pump Kit.
- Rear crank seal.
- Spark plugs.
- stamp_licker
jaffa pull the whole intake manifold off your existing motor with all the sensors injectors etc to put on your new motor.some of the turbo's run different tps sensors and a sensor is missing.this way you'll be able to plug str8 in.i guess that'll make 2 manifold gaskets to the list.Cheers Will
Building a hardcore postie:D
Thanks Fred, i think that the fuel pump is only 12 months old so fingers crossed.
Posite i will be trying to take as much as possible off the existing engine - i thought that they were different so thanks.
Oh and just to make this even more complex
When driving the car on the wkd i decided to put the a/c on, Thinking that this would kill the engine at idle, actually made it run smooooother
This problem is really getting to me... on a positive note though IF i can figure it out then no need to change engines.
- tim_81coupe
Jaffa, this does sound curable. However having the other EA82T is great anyway, provides good backup especially considering they are very scarce.
Get in touch with Molly and see if he's going to use that spider manifold, I'd guess not as somehow his flow bottleneck is the t/b, I believe he's making a hi-po EA82t and maybe he won't need that manifold. Spiders give you more power
As I've said before, I'll do as much as I can to help, unfortunately I can't this weekend but should be free next.
If you're going to pull the inlet manifold off, replace the small pipe that runs from the front of it, to underneath the manifold & attaches to the block.
It'll be just to the left of the power steer pump (or where it would be).
They have a tendency to break sometimes & the ONLY way to replace it is to pull the manifold off.
Replace it with EFI fuse hose & you'll never have to worry about it again.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
Previous rides:
OK, it would appear that after several months of head scratching the diagnosis is… Blown head gaskets 8O
Therefore, despite how very anil and anxious I am about this, I am thinking that I should get to work sooner rather then later. Those that wish to get their hands dirty you know where I live, and i am sure that we will be catering this event
I’ll get specifics on here once I know more, however the initial thoughts are... change engine, bolt/wire it up the same as the existing engine and in the process swap any bits from old engine onto new as the import is a newer engine- EG new engine has 3 wires comming out of the dizzy and the old only has 2 therefore use existing or old dizzy.
Your thoughts?
Thanks - L8a...
Your thoughts?
Thanks - L8a...
haha missed me.... :P
Actually, rebuilding an engine is something I'd like to help with. Never had to open up an engine in my life.
Current rides:
Previous rides:
Previous rides:
- tim_81coupe
