EA82T "Spider" Inlet Manifold ?
discopotato03
Post by discopotato03 » Thu May 03, 2007 11:34 am
I can't remember if I asked but does anyone have pics of this manifold . I did see one of this type on a Turbo Vortex but was not sure if it was some aftermarket American thing . Also something was said about the throttlebody opening in the opposite direction so the TPS won't work in a normal app .
Cheers Adrian .
brumbyrunner
Post by brumbyrunner » Thu May 03, 2007 12:45 pm
I don't know about the earlier ones but the 4wd Vortexs that we got had the spider manifold. The inlet faces to the rear of the engine and I always thought it would suit a topmount i/c.
schultzie
Post by schultzie » Thu May 03, 2007 4:09 pm
apart from suiting the top mount and what not a bit better are there any other advantages with using the spider manifold, like is the TB bigger?
L-series Ea82t, WAIC+BOV 1Bar, 15's, 5sp dr, WOLF3D V4+, =D
Post by Gannon » Thu May 03, 2007 4:20 pm
It has a larger throttle body and the intake runners are bigger and are a better shape.
The TPS is wired differently but is convertable.
NOTE: This TPS is designed for the 4 plug ecu only
It was supposed to add a few more HP. I think that is why the JDM vortex's had 130hp
schultzie
Post by schultzie » Thu May 03, 2007 4:44 pm
so with my wolf it should be ok... i think i need one
SCOOBIDOO
Spider = 130hp
Post by SCOOBIDOO » Thu May 03, 2007 9:31 pm
I Have 2 Of These Manifolds Lying Around....:-)
Post by steptoe » Thu May 03, 2007 11:09 pm
keep in mind i suspect these also used 41mm hole in flange turbo sits on, as opposed to the 36mm hole of aussie delivered.
130 HP.... got some torque figures for same thing Gannon ?
Xtreme_RX
Post by Xtreme_RX » Fri May 04, 2007 7:30 am
SCOOBIDOO wrote:I Have 2 Of These Manifolds Lying Around....:-)
How much do you want for one?????
http://www.subiparts.com.au
0438 887 746
SCOOBIDOO
130hp Manifold
Post by SCOOBIDOO » Fri May 04, 2007 7:32 pm
I am not sure what they would be worth to buy nowdays..though i do know they are extremely well suited with the wolf 3d ecu... i am currently enjoying 155 hp in a 550 kg vehicle.....what would you consider to be fair pricing on this item?..cheers
Post by Gannon » Fri May 04, 2007 10:18 pm
I dont know peak torque, but 130hp (97kw) at 5200 rpm equals 131.3ft/lb or 177 Nm at 5200rpm
Thats 21 Nm more than the 115hp engine at 5200 rpm
I couldnt find peak torque, i only calculated torque at peak power.
Post by Subafury » Fri May 04, 2007 11:31 pm
ooo maybe i should see if i can find one over here
sounds promising
discopotato03
Post by discopotato03 » Sat May 05, 2007 8:51 am
I did locate a pic of one of these manifolds but for some strange reason its sitting on an EA81 engine ? I wasn't aware that EA82 inlet manifolds could fit EA81 heads .
Cheers Adrian .
Xtreme_RX
Post by Xtreme_RX » Sat May 05, 2007 9:56 am
SCOOBIDOO wrote:I am not sure what they would be worth to buy nowdays..though i do know they are extremely well suited with the wolf 3d ecu... i am currently enjoying 155 hp in a 550 kg vehicle.....what would you consider to be fair pricing on this item?..cheers
You Have a PM...
0438 887 746
schultzie
Post by schultzie » Sat May 05, 2007 11:04 am
i want one as well......
Post by Gannon » Sat May 05, 2007 1:04 pm
Note that the pipe from the turbo to the throttle body is much smoother/better flowing than the normal ea82t
Top View, again notice the turbo-throttle body pipe
Image Installed in an RX turbo with what i think is a saab intercooler. Looks like a liberty WAIC or a wrx top mount would fit nicely.
Adrian, i very much doubt that it would have been the spider intake on an ea81. It physically wont fit. Although RAM engines and sub4 did make some ea81 dual intake heads and intake runners to match, designed specifically for aeroplanes
Custom 4 port ea81 head
140hp ea81 mpfi with custom 4 port heads
julian
Post by julian » Sat May 05, 2007 1:18 pm
Thanks for the pics, interesting stuff. 4 port heads on an EA81, that would be a cool project.
Julian
2004 Outback H6
2004 Forester XS
Organ donation saves lives
Post by Subafury » Sat May 05, 2007 1:46 pm
is there any other mods to make it fit- or simply bolt on??
now ive seen pics im very interested in one
discopotato03
Post by discopotato03 » Sat May 05, 2007 2:16 pm
Don't make me beg , how much for a manifold and crossover pipe . If its on a good engine how much ...
I'm going to have to do an engine anyway so will need another to rebuild because my RX is now the daily driver . Given a choise I'd like the Mass Air Sensor type which I take to mean the 4 plug computer setup . If the Vortex spec engine doesn't make as much torque down low thats fine because mine will spend 99% of its time on road .
Subaru the pic is on a partially assembled engine so it may have been an EA82 with the cam carriers missing . Probably my bad .
Cheers Adrian .
SCOOBIDOO
Post by SCOOBIDOO » Sat May 05, 2007 7:44 pm
Both manifolds are now spoken for..thanks for the speedy response...cheers
90brumby
Post by 90brumby » Sat May 05, 2007 9:29 pm
where did you get those heads???????? i want a set and also any more pis of them
tristan
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
