L Series connectors near brake master ??
Post by steptoe » Tue Apr 24, 2007 2:06 pm
I know quite often you find unused connectors but I have three just near the brake master and booster and begin to wonder...
it's an 85 GLTA
one is a square white connector 3 x 3 = 9 , but has 8 wires to it
two is square, blue, 2, 1, 2 connector with a bare connection plug on it
three is long flat yellowy-orange 4, 1, 4 = 9
a 92 model Sportswagon I looked at yesterday had just one, I think it was the square white plug - unused.
mind you the motor is not in for last year so i may have forgot, but was more concerned one may be for a overboost control i have heard about - but don't see ???
Post by Gannon » Tue Apr 24, 2007 5:51 pm
I think they are check connectors. The ones that they plug a diagnostic machine into.
I believe that if you have a multimeter, you can read outputs from sensors like coolant temp and o2 voltage ect. Even injector output if you have a dutycycle meter. But i could be misinformed.
PeeJay
Post by PeeJay » Tue Apr 24, 2007 6:41 pm
Yep, that sounds right.
Post by steptoe » Thu Apr 26, 2007 2:50 pm
hmmm, thanks
