Point's Brumby
Point
Point's Brumby
Post by Point » Sat Mar 31, 2007 1:26 pm
Another Brumby in Townsville!
Standard 1990 brumby.....for now :). I have plans, but want to get it on the road first. Doesn't look like it needs much.
thanks go to apesybabe for telling me about it.
Brumby Boy
Post by Brumby Boy » Sun Apr 01, 2007 12:39 am
Hay man good to see another townsville brumby floating round, we will have to catch up some time with matt, camo and the rest,
Welcome to the forums
RIP 1992 Brumby
vidler
Post by vidler » Sun Apr 01, 2007 9:26 pm
very nice. always good to see another brumby
09 Forester XT Touring Wagon
Point
Post by Point » Mon Apr 02, 2007 12:02 am
Thanks guys. I thought I did well for two grand. No rust either. So far I've got the dash apart and some other bits off to get rid of unwanted wiring. There's something funny with the rh headlight too. H4 globe works backwards?
now where do i find out if i can change the stud pattern to 4x114.3...
Point
Post by Point » Sun May 24, 2009 12:38 pm
So I figure i should update this thread, as I've been working slowly on my EJ22 conversion. I've chosen to use as much of the donor Liberty as I can, so I have cut down the front crossmember and incorporated the body lift into it. Also using the Lib control arms with custom brackets to mount the control arm bush using the original captive bolts in the body. This wouldn't work without the body lift as the bush is directly in line with the chassis rail. I'm currently working on the radiator support to fit the Lib radiator.
Some pics
98 Forester GX
02 Forester XS Luxury
Point
Post by Point » Sun May 24, 2009 12:41 pm
I've also been doing a bit on the inside too.
This is the bracket to hold the Lib column in
and I've done a bit of chopping and reshaping of the Lib loom. I'm using most of it and replacing the original Brumby loom.
98 Forester GX
Post by El_Freddo » Mon May 25, 2009 10:48 am
That's looking awesome! I like your idea of using as much liberty for your conversion as possible. I'm guessing you'll get the lib dash cut down to fit in the brumby?
Last thing you should put on it is a rear window sticker - "Liberty inside" - for shits and giggles, at least til someone recognises everything as liberty in the brumby (then watch their face drop).
Keep up the good work. How long's it taken you so far?
Point
Post by Point » Mon May 25, 2009 6:53 pm
using the original Brumby dash, but with the Lib instruments and combination switch. There was too much of a difference in dash width to consider cutting it down.
so far the car has been off the road for just over a year. I have a few other projects that I'm working on like house extensions, and a few other cars. That and I'm easily distracted... :p
I do miss my Brumby though
98 Forester GX
Point
Post by Point » Mon Sep 13, 2010 10:41 am
Got a package in the post today...
98 Forester GX
T'subaru
Post by T'subaru » Mon Sep 13, 2010 11:02 am
Point wrote:Thanks guys. I thought I did well for two grand. No rust either. So far I've got the dash apart and some other bits off to get rid of unwanted wiring. There's something funny with the rh headlight too. H4 globe works backwards?
Heres a company I ran across as im considering a similar change, about 60.00 US per corner.
Nice Brumby...and no rust,sweet:cool:
http://shop.adapterkings.com/Car-Truck-Adapters_c2.htm
T'subaru
Post by T'subaru » Mon Sep 13, 2010 11:06 am
Nice Brumby Point! :cool:
Post by El_Freddo » Tue Sep 14, 2010 1:01 pm
Umm... I'm a little bit jealous right now!
Good effort, can't wait to see it on your brumby - how's it all been going anyway, its been a few drinks between posts!
Benni
Point
Post by Point » Fri Sep 17, 2010 2:06 pm
now with matching shoes!
yeah I am a bit slow with this project.... but here's a photo of my yard, showing my Subaru addiction. see if you can find all of them...
now i just have to pull the motor out of the white foz to fix an oil leak, take the box out of the lib wagon and put it into the sedan, put a manual in the wagon.....and it goes on....
98 Forester GX
Post by TOONGA » Fri Sep 17, 2010 4:40 pm
I spot six if the one behind the trailer is a subi
your brumby is looking good nice and straight well done
Post by sven '2' » Fri Sep 17, 2010 6:22 pm
Now that ^^^ is some serious bracket work - well done
Point
Post by Point » Fri Sep 17, 2010 7:11 pm
TOONGA wrote:I spot six if the one behind the trailer is a subi
yeah it is, but there's another under the brown tarp behind that one. seven all up.
98 Forester GX
Post by TOONGA » Fri Sep 17, 2010 7:19 pm
Point wrote:yeah it is, but there's another under the brown tarp behind that one. seven all up.
lol I thought that was a fence I see it now
suba1
Post by suba1 » Sun Sep 19, 2010 10:26 pm
can anyone tell me how to post ane thread topic as I'm going to be doing abrumby wrx conversion
I'm sure there is heap's of helpfull link's on here have already found just finding it annoying I can't find where to post a new thead topic
Point
Post by Point » Sun Sep 19, 2010 11:26 pm
go into a forum section eg.
AUSubaru.com Forums > General > Members area > My Car
and there is a button near the top on the left
98 Forester GX
Point
Post by Point » Tue Sep 21, 2010 11:27 pm
just made up this quick animation of the crossbred kit installation....
98 Forester GX
