94 Liberty Wagon Fuel Sender Unit
maddog
Post by maddog » Fri Feb 02, 2007 7:14 pm
Hi All - My mate has a 94 Subaru GX Wagon - and it's a nice one! - but the fuel gauge has a mind of its own. His mechanic has told him it's the sender unit in the fuel tank and it'll be a $400 to $500 job to fix.
How hard is it to change the sender unit? (how hard can it be!)
Does anyone have a spare one lying around? (hope so...!)
Thanks for all your inputs in advance!!! ;o)
88 GL Touring Wagon - getting better all the time... or was until Skippy got in the way one night... writeoff now :(
98 Forester - wotaluvlycar! (belongs to missus) ;o)
91 Liberty Wagon in immaculate condition - can't believe how much nice it is, mine! ;)
Brumby Boy
Post by Brumby Boy » Sat Feb 03, 2007 6:20 am
not too hard. pritty sure its either on the floor in the front of the boot, or under the rear sat on the rh side.
RIP 1992 Brumby
chriSTIan
q
Post by chriSTIan » Sat Feb 03, 2007 8:32 am
2wd have 1 sender 4wd have 2
Can also be the gauge itself,happened to me once.
What is the problem with it?
CC
Post by AlpineRaven » Mon Feb 05, 2007 7:34 pm
Liberty are known to have bad fuel senders, go to RSLC and do a search, there is a good instructions to tell you how to clean them, but if you keep cleaning them they wear out... common problem for Liberty.
My best advice to avoid spending upto $450-$500 (I got a quote around $218 for one side and other was just under $300) best way is to reset ODO every re-fill stop and an EJ22 Liberty would go upto around 550 - 650-700kms to a tank, focus on the fuel pump light - they are normally accurate which will come on around 7-8litres remaining in tank which could last you estimation 50 kms (city) or 70-100kms on highway.. This is what I do with mine, once it goes half tank the gauge plays up as its the sender unit - NOT the gauge at fault.
chriSTIan wrote:2wd have 1 sender 4wd have 2
CC
Correct - AWD/4WD has left and right senders, on drivers side is the main one.
FWD is on the drivers side.
