any one fitted a super charger
tassyflyer
hi considering buying a super charger is there any where i can find tech info,mabee 1 of our family has played with one and using it hmmm all the best .oh my eng ea 81in ute ea 82 also in shed as a back up
- tim_81coupe
- BaronVonChickenPants
Steve is your Man for this, he runs a blown EA82 in a buggy and it puts out good power levels.
Points to remember-
most superchargers dont like fuel going through them, as such Steve is running LPG through a toyota mr2 blower.
The petrol eats the seals apparently.
Most carbies also hate blow through action - SU's are the only ones I know which will handle it, let me know if you want one, I have 2 x 1 3/4" ones here.
You will battle if you have either power steering or A/C - there is not a heap of room in there to keep the blower below the bonnet line.
I AM SO TEMPTED AS WELL, I have the Blower, the gas, the bad attitude, I am just a little scared of putting 6psi in a standard EJ22.
Opinions??
Points to remember-
Opinions??
1989 Subaru WonderBrumby II
- tim_81coupe
tassyflyer
q
Can you run a s/charger on an ej22 using a turbo harness/ computer?
Will the ignition retard work and would all the boost controls match up?
Thinking of running max 10psi.
Will the ej22 block and std pistons handle such boost??
Thanx
CC
Thanx
CC
