extreeme overheating
yesterday my car (ea82t) started to overheat from just normal driving (like half an hour drive) on the way for some sand 4x4. by the time i got there temp needle was just before the red. normal operating temp is like a 1/4 or a third up the gauge. throughout lots of cooling down periods temp fluctuated between just over half and up to the red. i even got it to there on way home from work today-10mins.
obviously checked coolant, both fans (including new thermo), oil etc. water pump seems fine too. rad fins arent blocked. any other ideas?
there is one other thing- i remember i had just put in a little morey's upper cyl lube/injector cleaner after hearing about how good it is, and it says can also be used as lead replacent. would this cause my overheating?
else i may just take it to a rad shop as need it fixed by this w/e. argh!
cheers for suggestions
matt.
matt.
Any steam coming out of the exhaust???
Dave
Dave
Second Mattim's suggestion. Definitely remove the thermostat and run it without it to test, it's probably not opening propperly.
Chuck the thermostat in a cooking pot of water on the stove and watch it to see if it opens too.
EZ30 L series - Monsterwagon
Agreed... only takes a small air bouble sitting above the thermostate to stop even a working thermostate opening... remove it to be sure.
Dave
Dave
- Captain Obvious
get antother radiator i reckon and try that or take yours out and give the fins a good clean as they could have mud it it also check the water it the overflow bottle is getting filled and over flowing it could be a blown head gasket, they leak into the water jacket on boost and pressurise the cooling system..
bryan
bryan
as i recall your carby has had cooling issues as well ales...
dave
dave
mmmm nar not really...not red lining..just 2/3rds
ea82's are awesome dude! she sits on about 1/8th temp all day long
sounds similar to my problem, only now i think its had it!! its worse!!
my temp used to fluctuate after about 40 mins of normal driving,
but i've had 3 thermostats, a new radiator and a c02 test (came back all good) nothing helps, i still cant find the prob.
Erica ..
95 Liberty sedan
previous cars:
88 RXturbo sedan (aww i miss you)
83 GLFA leone coupe
95 Liberty sedan
previous cars:
83 GLFA leone coupe
Just remember EA's are great for bizarre ways of blowing head gaskets or just weird things like corroded out cooling galleries.
I drove my last MPFI for nearly 1 year with a blown head gasket (usto get hot hot!). Basically used fuck all water or showed any signs of a blown head. Then when the unspeakable happened and I had to strip the car I noticed the head gasket.
Hunter S. Thompson
Hunter S. Thompson
DO NOT under estimate the effects of a faulty radiator cap... maybe look into that too.
Dave
Dave
