extreeme overheating
Post by Subafury » Mon Nov 27, 2006 8:21 pm
yesterday my car (ea82t) started to overheat from just normal driving (like half an hour drive) on the way for some sand 4x4. by the time i got there temp needle was just before the red. normal operating temp is like a 1/4 or a third up the gauge. throughout lots of cooling down periods temp fluctuated between just over half and up to the red. i even got it to there on way home from work today-10mins.
obviously checked coolant, both fans (including new thermo), oil etc. water pump seems fine too. rad fins arent blocked. any other ideas?
there is one other thing- i remember i had just put in a little morey's upper cyl lube/injector cleaner after hearing about how good it is, and it says can also be used as lead replacent. would this cause my overheating?
else i may just take it to a rad shop as need it fixed by this w/e. argh!
cheers for suggestions
matt.
SuBaRiNo
Post by SuBaRiNo » Mon Nov 27, 2006 8:55 pm
Any steam coming out of the exhaust???
Dave
mattims
Post by mattims » Mon Nov 27, 2006 8:57 pm
simple check might be thermostat problems .. try taking it out and running to see if it still overheats... or it could be a water pump problem
Post by AndrewT » Mon Nov 27, 2006 9:01 pm
Second Mattim's suggestion. Definitely remove the thermostat and run it without it to test, it's probably not opening propperly.
Chuck the thermostat in a cooking pot of water on the stove and watch it to see if it opens too.
Post by steptoe » Mon Nov 27, 2006 9:06 pm
my thoughts exactly
SuBaRiNo
Post by SuBaRiNo » Mon Nov 27, 2006 9:12 pm
Agreed... only takes a small air bouble sitting above the thermostate to stop even a working thermostate opening... remove it to be sure.
Dave
wrx_nut
Post by wrx_nut » Mon Nov 27, 2006 9:24 pm
yer check your thermostat... also check your radiator wires are connected and it might be a good idea to flush your radiator out with a hose...
wrx_nut
85' Touring Wagon, EA82T, 3" Lift, 27's, RS intercooler
90' Brumby (B&S Project!) still cutting rust :P
Post by Subafury » Mon Nov 27, 2006 11:16 pm
mmk took thermostat out-was pretty easy. tested it in boiling water and opens up fine. will put some water back in n run with out it now to test car.
Post by Subafury » Tue Nov 28, 2006 12:58 am
tested car with no thermostat. after 10 mins of flogging it round the block temp still went up, gettin close to the red. ill see if i can get it into balcatta rads tomoz coz i dont know whats going on.
Milla
Post by Milla » Tue Nov 28, 2006 1:29 am
when i took my EA82 in for service they didn't bolt on the pully for the 2nd fan properly, i only did it finger tight and it got me home
wrx_nut
Post by wrx_nut » Tue Nov 28, 2006 9:09 am
id be checking your temp sensors as iv had one stuff up in the vortex and giving bad readings.... i actully put another radiator in it and it was fine...
Post by Subafury » Tue Nov 28, 2006 1:08 pm
put thermostat back in this morning and gave it a 15 min thrash round the block again. but could only get the temp to just above half. hmmm it has sorta fixed itself.....more testing necessary i think.
Captain Obvious
Post by Captain Obvious » Tue Nov 28, 2006 4:53 pm
get antother radiator i reckon and try that or take yours out and give the fins a good clean as they could have mud it it also check the water it the overflow bottle is getting filled and over flowing it could be a blown head gasket, they leak into the water jacket on boost and pressurise the cooling system..
bryan
Post by Alex » Tue Nov 28, 2006 8:06 pm
maybe you should just get a carby motor? hahaha
Post by D3V1L » Tue Nov 28, 2006 8:09 pm
as i recall your carby has had cooling issues as well ales... ;)
dave
Post by Alex » Tue Nov 28, 2006 8:57 pm
mmmm nar not really...not red lining..just 2/3rds :) ea82's are awesome dude! she sits on about 1/8th temp all day long :)
subby
Post by subby » Tue Nov 28, 2006 9:00 pm
sounds similar to my problem, only now i think its had it!! its worse!!
my temp used to fluctuate after about 40 mins of normal driving,
but i've had 3 thermostats, a new radiator and a c02 test (came back all good) nothing helps, i still cant find the prob.
Erica ..
95 Liberty sedan
previous cars:
88 RXturbo sedan (aww i miss you)
83 GLFA leone coupe
BrennyV
Post by BrennyV » Tue Nov 28, 2006 9:10 pm
Just remember EA's are great for bizarre ways of blowing head gaskets or just weird things like corroded out cooling galleries.
I drove my last MPFI for nearly 1 year with a blown head gasket (usto get hot hot!). Basically used fuck all water or showed any signs of a blown head. Then when the unspeakable happened and I had to strip the car I noticed the head gasket.
Hunter S. Thompson
SuBaRiNo
Post by SuBaRiNo » Tue Nov 28, 2006 10:47 pm
DO NOT under estimate the effects of a faulty radiator cap... maybe look into that too.
Dave
Post by steptoe » Tue Nov 28, 2006 10:47 pm
I've just finished pulling apart my 3rd EA82 this year or was that four, and all had beautifully intact head gaskets. Some heads were cracked though!
Return to “Trouble Shooting”
