Brake light info
Lapsed
Brake light info
Post by Lapsed » Fri Oct 27, 2006 9:47 am
just a small thing i found out about the l series yesterday. My steering rack has been leaking fluid for a little while now, about a fortnight ago the brake fluid light came on, so i check the brake fluid its fine. I 'm thinking great another problem (YAY). till yesterday when i refill the power steering fluid and now the light is off... so the story is that the brake fluid light doesn't just mean the brake fluid is low it also means that the power steering is low.
cheers chris
SUBARU OFF-ROAD RECOVERY VEHICLE
BlackMale
Post by BlackMale » Fri Oct 27, 2006 10:35 am
OR Vidler and Subarino wired it up incorrectly LOL
Post by AndrewT » Fri Oct 27, 2006 10:57 am
Wow thats really strange. I don't recall any wires for a sensor in the power steering pump. Must be Subaru's Sixth Sense! :p
coupe
eek
Post by coupe » Fri Oct 27, 2006 5:05 pm
Right about now we should be hearing the TWILIGHT ZONE music playing
Use The Fork Luke
Post by AndrewT » Fri Oct 27, 2006 5:40 pm
Post by Alex » Fri Oct 27, 2006 7:07 pm
hahahaha.....
Lapsed
Post by Lapsed » Fri Oct 27, 2006 8:44 pm
Jaffa wrote:OR Vidler and Subarino wired it up incorrectly LOL
More than likely it :)
This one sounds better though
SuBaRiNo
Post by SuBaRiNo » Fri Oct 27, 2006 8:55 pm
I know of 2 people that aint getting any more things wired by me. I think my wiring quality can speak for itself. And the 10 grand pay raise i just got from work backs that up.
P.S i never touched that wiring.
There is much more chance u got the resevours mixed up then my wiring being dodgy. LOL
Dave
SUBYDAZZ
Post by SUBYDAZZ » Wed Nov 08, 2006 1:18 pm
I've found sometimes that brake fluid indicator comes on for no apparent reason, or when it is over-filled.
I'll put this event down to co-incidence rather than wiring mistake or otherwise. you could test it by sucking out some P/S fluid and seeing if the brake fluid light ocmes back on.
SUBYDAZZ
Post by El_Freddo » Wed Nov 08, 2006 5:02 pm
Maybe there's a dodgy wire that requires p/s fluid to be on it so the light stays off, you ran out of fluid... Meaning that you filled the p/s fluid so it could again leak and fill the connection of the dodgy wire, thus leaving the light off.
My two cents on this event...
Return to “Trouble Shooting”
