EA82 coolant/overflow bottle problem
Hey Everyone, I`ve only in the last 2 months became a L-series EA82 MPFI wagon owner. My problem is everytime I run the wagon on med - long trips and switch the motor off the coolant goes to the overflow bottle (thats normal).HOWEVER it never seems to return, and the more i use the wagon through the day stop-start-stop-start it slowly emptys my radiator - therefore leading to a hotter than usual motor. Ofcourse i have cleaned the overflow bottle out, and the over flow hose is not abstructed, replaced radiator cap and made sure it was the right one? Got me beat!
My wagon due to the constant filling required of the radiator does have water bubbles when filling (they would be air bubbles that are normal when fillling). As for the radiator i have flushed it out and it seems to drain freely. My main problem as mentioned above is that the overflow bottle will not return the coolant back to the radiator.
- Suby Wan Kenobi
- Suby Wan Kenobi
I've had this problem in the past. I'd say if the rad/thermo/heater isn't blocked, a small leak may not push out much coolant, but will easily suck in air when cooling, so not allow the coolant back in. dunno mate. mine used to push out the coolant as you've described, and maintain pressure in the system even after cooling down. course when I put in the new engine, rad, water pump, etc etc it went away.....
