Centre brake light in wiring loom even if not fitted?
Hey everyone, does any one know if the L series has a factory plug in the tail gate wiring loom for the centre mount brake light just hanging there - even if like my wagon (89` touring EFI) it did not have a centre stop light fitted when it was brand new. The reason i ask this is my father had a late 80`s camry and i fitted a centre mount stop light and there was a plug in the factory loom just hanging there in the boot for the models with it fitted so i connected it to that. I`m not game to take the tailgate trim off yet to have a look.
You might find your tailgate has the wiring, but there's nothing to plug it into on the loom itself, or that might be vice versa.
You may find there's a spare plug near the RHS taillight cluster in behind the trim.
I'm wiring one up for my 88, but I'm thinking about installing a roof spoiler with a built in brake light, so I want to have the wires there ready to go.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
Previous rides:
Right you are wagonist the plug is hanging in the rear of the RH tail light on the wiring loom that goes up to the roof, i decided to pull the tailgate trim - broke a couple of the clips (i knew i would) and there was a plug and even the holes in the tail gate for the centre mount stop light. Now all i have to do is find a cheap an L series centre stop light, i mean cheap.
If your refering to the L- series smokey the third brake light is mounted centrally at the bottom of the rear window. I discovered today as mentioned above there is a green/black wire/plug hanging around at the rear of the RH tail light and in the tailgate (after removing trim) is a 2 wire plug: green/black and a black wire for earth, holes are there, ready for me to fit, So Wagonist check your pm, sound like smokey`s considering one too. Does anyone know (if u have an L-series with third brake light fittted) do they have a groove cut around the light in the tail gate trim or is the top of the trim dead straight (left to right)
Wagonist, if you do get a roof mounted spoiler, post a pic up if you do it, and what its from?wagonist wrote:You might find your tailgate has the wiring, but there's nothing to plug it into on the loom itself, or that might be vice versa.
My '89 Tourer hasnt a rear brake light either, didnt even think about it as the old MY hasnt got one - just got used to not having one. But when I replaced the rear inside plasic panel, I seem to recall a spare plug wiring.....hmm, migh look into this, but my window tint is so dark, that the light would have to be 50W to see it LOL!
- Chris_Rogers
Unless it's an 89 or 90 model, you'll find that it doesn't fit.jono wrote:my L series sedan (still motor - less ) has all the structure that looks to hold/mount a middle brake light too !
I fitted one from an 89 Leone Royale to my 85 sedan about 10 years ago now.
After slotting both holes where I thought it would mount by a long way, it finally fit.
Don't do it, fit a ski blade boot spoiler with a light instead.
The wagons simply need a hole cut out of the tailgate trim to fit (at least on the post 88 models, dunno about earlier ones, but I can check before I post mine off)
