Diesel Particulate Filter - DPF
VW DSG auto transmission used fluid that was corrosive to the internal TCM.steptoe wrote:This tragedy you refer to is still in the hands of the coroner isn't it ?
Motor journo Will Hagon was saying the other night the problem VW are having seems to be with the Diesel engine/DSG box in the majority - and it is the gearbox, or is it a transmission? that is the component being attended to in order to correct fault whereas it is the polution control side of the Diesel engines in the Subes copping the blame and attention.
Diesel Particulate Filter Permanent Fix
Returned today to advise after 2 years of research we have a permanent fix for this DPF issue to find we have been barred from this forum, seems the administrators don't want this fix displayed.
No reason has been given which tells us a lot about the administrators of this forum.
http://www.autoscan.net.au automotive diagnostics made easy.
- TOONGA
autoscan1 wrote:Returned today to advise after 2 years of research we have a permanent fix for this DPF issue to find we have been barred from this forum, seems the administrators don't want this fix displayed.
Actually advertising for your first 4 posts, 1. without consulting the moderators or Administrator and 2. without even thinking about becoming a gold subscriber, says a lot about your business practices.
read the rules
showthread.php?t=12409
If you want to advertise your business, ask the right people / donate to keep the board running, then by all means advertise.Unsolicited advertisements by retail outlets or of non-AUSubaru endorsed businesses and websites are not permitted. Likewise, non-genuine classifieds advertisements (as determined by the Management Team) are not permitted. Any such posts will be deleted.
+1.. if not going to be helpful then just pay the Admin a fee and then advertise your business.. how hard is that?sublime wrote:What fix? You have not displayed or detailed any fix... Just spruiked for a business.
DPF monitoring
I now monitor my DPF regens through an OBD-II Bluetooth interface and Torque Pro on Android. At least it warns me during the DPF regen.
Thanks to Ghostgum (and Subdiesel/ Subaru diesel crew site) for the PIDs to get me going, I was stuck figuring it out!
Note the temps in this image are somewhat extreme and don't normally go that high (more around the 600-650C level).
Patrick
Ex- 2010 Forester Diesel
DPF Temp PIDs
Hi Ghostgum,ghostgum wrote:What PID values did you use for those temperatures?
See here for the details of the following:
- Estimated DPF Temperature Mode And PID: 22114C
- Estimated Catalyst Temperature Mode And PID: 22114B
- Exhaust Gas Temp at DPF Mode And PID: 22003E
Patrick
Awesome and must get TP.. thankspitrack_1 wrote:I now monitor my DPF regens through an OBD-II Bluetooth interface and Torque Pro on Android. At least it warns me during the DPF regen.
Can you data log this info?
Torque logging
No probsRSR 555 wrote:Awesome and must get TP.. thanks
Yes. Text CSV (comma delimited) file, easily importable to just about anything. You can select the parameters to log. Many options. GPS too if you wish to track your drive.RSR 555 wrote:Can you data log this info?
Here's a sample with the DPF turning on (value 0 -> 255). Copy the lines below (note word wrapping may interfere with the full line) into a text file, save with .csv extension, import into excel (should give lots of columns) and plot Time vs DPF Active Regeneration Switch as a scatter line graph.
Device Time, G(x), G(y), G(z), G(calibrated),DPF Active Regeneration Switch(on/off),Glow Relay Switch(on/off),Oil Dilution Ratio(%),Soot Accumulation Ratio(%),Exhaust Gas Temp at DPF(°C),Estimated Catalyst Temperature(°C),Estimated DPF Temperature(°C),Accelerator PedalPosition D(%),Accelerator PedalPosition E(%),Engine RPM(rpm),Speed (OBD)(km/h),Intake Air Temperature(°C),Throttle Position (%)(%),DPF Active Regeneration Count
30-Apr-2014 19:28:12.679,-5.4185791,-0.5872345,7.96228027,0.00259101,0,0,3,64,214.19999695,210,215,13.33333397,13.33333397,1641.25,60,18,-,254
30-Apr-2014 19:28:13.254,-5.4185791,-0.5872345,7.96228027,0.00259101,0,0,3,64,214.19999695,210,215,13.33333397,13.33333397,1649,60,17,-,254
30-Apr-2014 19:28:13.801,-5.4185791,-0.5872345,7.96228027,0.00259101,0,0,3,64,213.3999939,210,215,13.33333397,13.33333397,1651.25,60,17,-,254
30-Apr-2014 19:28:14.364,-5.4185791,-0.5872345,7.96228027,0.00259101,255,0,3,63,213.3999939,210,215,13.33333397,13.33333397,1656.5,60,17,-,254
30-Apr-2014 19:28:14.930,-5.4185791,-0.5872345,7.96228027,0.00259101,255,0,3,64,213,210,215,13.33333397,13.33333397,1662,61,17,-,254
30-Apr-2014 19:28:15.488,-5.4185791,-0.5872345,7.96228027,0.00259101,255,0,3,64,212.6000061,210,215,13.33333397,13.33333397,1671.5,61,17,-,254
Patrick
Excellent. It would be good to know what terrain the car is on while this is happening, so GPS would work great.pitrack_1 wrote:Yes. Text CSV (comma delimited) file, easily importable to just about anything. You can select the parameters to log. Many options. GPS too if you wish to track your drive.
Sounds good. I just had word from my Subaru Rep that our 2010 Foz has had the "upgrade" to the ECU to help with the DPF fault. Once I have our Data Log I'll let you know what mine looks like.pitrack_1 wrote:Here's a sample with the DPF turning on (value 0 -> 255). Copy the lines below (note word wrapping may interfere with the full line) into a text file, save with .csv extension, import into excel (should give lots of columns) and plot Time vs DPF Active Regeneration Switch as a scatter line graph.
Doubt you see this from the marketers.. Manufactures don't want people seeing this info but it's been available to them since EFIsteptoe wrote:Waa, what next ?! Wait 'til the marketers get onto this, no worries about vehicles reliability, performance or longevity. Right now the ads only seem to spruik no need to buy after market stuff coz it all comes with sat nav, bluetooth, auto park assist and now Torque Pro !
Torque Pro et al
There's a few holes, but overall Torque Pro is a very nice piece of work. It even has a 'HUD' mode- reverses the readout (R to L) for display by reflection off the windscreen.
My interface is on the blink (or I've damaged the plug/socket ), see error below, so buying a new (better) one- should hopefully have SSM access/capability too. Will let you know how it goes.
Some info for you, RSR555:
- There have been a few instances (lots for me recently) of code U0073 (Network Error) being thrown. This can be cleared with Torque Pro, has been suspected it may even be caused by Torque Pro on occasion. Mine may be my interface failing. I have logged many Mb and hours without any issue previously. The symptom is the Christmas tree lights up, complete with flasher. You'll know what I mean when it happens
- U0073 whist driving produces unpredictable results. Sometimes the performance is impeded, the steering may drop to a default (min) assistance level, lots of electronic bits don't work (including after recycling ignition) incl cruise, have had a rpm limit ~3000 once, seems to lose knock sensing/balancing at idle, etc.
- For when you're finding stuff in Torque Pro, storage directories are all over the place. Some I've found are (on a Nexus 7 2013):
- /storage/emulated/0/.torque (various- config save files and logs)
- /storage/emulated/0/.torque/tripLogs (for the GPS logs I think- GPS not activated by me)
- /storage/emulated/0/torqueLogs (data logs, can include GPS readouts if specified I think)
- /storage/emulated/0/torqueTrackLog.csv (seems to be a GPS dedicated log file)
- A Nexus 7 2013 seems it could fit nicely where the stereo (if it can be called that) unit is in a 2010
Patrick
Excellent pitrack_1
I just got given a Nexus 7 tablet for helping a friend put his supercharger in his Nissan 350Z, so I will put this tablet straight to good use
Paul
Paul
Nexus 7 and Torque Pro
Hi Paul,RSR 555 wrote:Excellent pitrack_1
Well then here's a couple of files to get you started. Unzip the attached .zip, the two files inside for Torque Pro DPF monitoring are the dash setup and custom PIDs. Drop them in the appropriate directories under /storage/emulated/0/.torque/dashboards and /storage/emulated/0/.torque/extendedpids .
To do this, you'll need a file manager type program (free downloads) such as Ghost Commander (can send your logs to PC via Bluetooth) and File Commander (can act as a very basic music player- queue audio files, see below).
And the Nexus 7 (2013 or version 2) plugs nicely into the AUX-IN port (centre console bottom rear, underneath centre armrest on the 2010) to act as a music box too. You just need a standard stereo headphone socket (2.5mm?) male-male link cable.
Patrick.
- Forester_DPF_Monitoring.zip
- (2.62 KiB) Downloaded 445 times
Patrick
