Diesel Particulate Filter - DPF
Autoscan
Post by Autoscan » Sun Apr 06, 2014 3:16 pm
We can regenerate or force regenerate your Subaru outback diesel
At your place and will have a permanent fix for this in the coming
Weeks. We can force regenerate after soot content has exceeded
135%, when you dealer claims your DPF cannot be regenerated
We can do it. http://www.autoscan.net.au
Autoscan
Post by Autoscan » Sun Apr 06, 2014 6:56 pm
steptoe wrote:This tragedy you refer to is still in the hands of the coroner isn't it ?
Motor journo Will Hagon was saying the other night the problem VW are having seems to be with the Diesel engine/DSG box in the majority - and it is the gearbox, or is it a transmission? that is the component being attended to in order to correct fault whereas it is the polution control side of the Diesel engines in the Subes copping the blame and attention.
VW DSG auto transmission used fluid that was corrosive to the internal TCM.
autoscan1
Diesel Particulate Filter Permanent Fix
Post by autoscan1 » Tue Apr 08, 2014 8:12 pm
Returned today to advise after 2 years of research we have a permanent fix for this DPF issue to find we have been barred from this forum, seems the administrators don't want this fix displayed.
No reason has been given which tells us a lot about the administrators of this forum.
http://www.autoscan.net.au automotive diagnostics made easy.
Post by TOONGA » Tue Apr 08, 2014 8:59 pm
autoscan1 wrote:Returned today to advise after 2 years of research we have a permanent fix for this DPF issue to find we have been barred from this forum, seems the administrators don't want this fix displayed.
Actually advertising for your first 4 posts, 1. without consulting the moderators or Administrator and 2. without even thinking about becoming a gold subscriber, says a lot about your business practices.
read the rules
showthread.php?t=12409
Unsolicited advertisements by retail outlets or of non-AUSubaru endorsed businesses and websites are not permitted. Likewise, non-genuine classifieds advertisements (as determined by the Management Team) are not permitted. Any such posts will be deleted.
If you want to advertise your business, ask the right people / donate to keep the board running, then by all means advertise.
Tigger
Post by Tigger » Wed Apr 09, 2014 10:27 am
Thank you TOONGA :)
sublime
Post by sublime » Wed Apr 09, 2014 1:49 pm
autoscan1 wrote:seems the administrators don't want this fix displayed
What fix? You have not displayed or detailed any fix... Just spruiked for a business.
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
Post by El_Freddo » Mon Apr 14, 2014 6:53 pm
I'm with you Toonga! Has there been a thread started to notify the moderators?
Post by RSR 555 » Thu Apr 24, 2014 12:46 pm
sublime wrote:What fix? You have not displayed or detailed any fix... Just spruiked for a business.
+1.. if not going to be helpful then just pay the Admin a fee and then advertise your business.. how hard is that?
Post by El_Freddo » Sat May 03, 2014 11:28 am
He knows NOTHING of the FIX!
:rolleyes:
pitrack_1
DPF monitoring
Post by pitrack_1 » Sat May 03, 2014 2:25 pm
I now monitor my DPF regens through an OBD-II Bluetooth interface and Torque Pro on Android. At least it warns me during the DPF regen.
Thanks to Ghostgum (and Subdiesel/ Subaru diesel crew site) for the PIDs to get me going, I was stuck figuring it out!
Note the temps in this image are somewhat extreme and don't normally go that high (more around the 600-650C level).
Patrick
Ex- 2010 Forester Diesel
ghostgum
Post by ghostgum » Sat May 03, 2014 8:03 pm
What PID values did you use for those temperatures?
pitrack_1
DPF Temp PIDs
Post by pitrack_1 » Sat May 03, 2014 10:59 pm
ghostgum wrote:What PID values did you use for those temperatures?
Hi Ghostgum,
See here for the details of the following:
  • Estimated DPF Temperature Mode And PID: 22114C
  • Estimated Catalyst Temperature Mode And PID: 22114B
  • Exhaust Gas Temp at DPF Mode And PID: 22003E
Patrick
Post by RSR 555 » Tue May 06, 2014 11:41 am
pitrack_1 wrote:I now monitor my DPF regens through an OBD-II Bluetooth interface and Torque Pro on Android. At least it warns me during the DPF regen.
Awesome and must get TP.. thanks
Can you data log this info?
pitrack_1
Torque logging
Post by pitrack_1 » Tue May 06, 2014 10:32 pm
RSR 555 wrote:Awesome and must get TP.. thanks
No probs :-)
RSR 555 wrote:Can you data log this info?
Yes. Text CSV (comma delimited) file, easily importable to just about anything. You can select the parameters to log. Many options. GPS too if you wish to track your drive.
Here's a sample with the DPF turning on (value 0 -> 255). Copy the lines below (note word wrapping may interfere with the full line) into a text file, save with .csv extension, import into excel (should give lots of columns) and plot Time vs DPF Active Regeneration Switch as a scatter line graph.
Device Time, G(x), G(y), G(z), G(calibrated),DPF Active Regeneration Switch(on/off),Glow Relay Switch(on/off),Oil Dilution Ratio(%),Soot Accumulation Ratio(%),Exhaust Gas Temp at DPF(°C),Estimated Catalyst Temperature(°C),Estimated DPF Temperature(°C),Accelerator PedalPosition D(%),Accelerator PedalPosition E(%),Engine RPM(rpm),Speed (OBD)(km/h),Intake Air Temperature(°C),Throttle Position (%)(%),DPF Active Regeneration Count
30-Apr-2014 19:28:12.679,-5.4185791,-0.5872345,7.96228027,0.00259101,0,0,3,64,214.19999695,210,215,13.33333397,13.33333397,1641.25,60,18,-,254
30-Apr-2014 19:28:13.254,-5.4185791,-0.5872345,7.96228027,0.00259101,0,0,3,64,214.19999695,210,215,13.33333397,13.33333397,1649,60,17,-,254
30-Apr-2014 19:28:13.801,-5.4185791,-0.5872345,7.96228027,0.00259101,0,0,3,64,213.3999939,210,215,13.33333397,13.33333397,1651.25,60,17,-,254
30-Apr-2014 19:28:14.364,-5.4185791,-0.5872345,7.96228027,0.00259101,255,0,3,63,213.3999939,210,215,13.33333397,13.33333397,1656.5,60,17,-,254
30-Apr-2014 19:28:14.930,-5.4185791,-0.5872345,7.96228027,0.00259101,255,0,3,64,213,210,215,13.33333397,13.33333397,1662,61,17,-,254
30-Apr-2014 19:28:15.488,-5.4185791,-0.5872345,7.96228027,0.00259101,255,0,3,64,212.6000061,210,215,13.33333397,13.33333397,1671.5,61,17,-,254
Patrick
Post by steptoe » Wed May 07, 2014 7:36 am
Waa, what next ?! Wait 'til the marketers get onto this, no worries about vehicles reliability, performance or longevity. Right now the ads only seem to spruik no need to buy after market stuff coz it all comes with sat nav, bluetooth, auto park assist and now Torque Pro !
Post by RSR 555 » Wed May 07, 2014 11:41 pm
pitrack_1 wrote:Yes. Text CSV (comma delimited) file, easily importable to just about anything. You can select the parameters to log. Many options. GPS too if you wish to track your drive.
Excellent. It would be good to know what terrain the car is on while this is happening, so GPS would work great.
pitrack_1 wrote:Here's a sample with the DPF turning on (value 0 -> 255). Copy the lines below (note word wrapping may interfere with the full line) into a text file, save with .csv extension, import into excel (should give lots of columns) and plot Time vs DPF Active Regeneration Switch as a scatter line graph.
Sounds good. I just had word from my Subaru Rep that our 2010 Foz has had the "upgrade" to the ECU to help with the DPF fault. Once I have our Data Log I'll let you know what mine looks like.
steptoe wrote:Waa, what next ?! Wait 'til the marketers get onto this, no worries about vehicles reliability, performance or longevity. Right now the ads only seem to spruik no need to buy after market stuff coz it all comes with sat nav, bluetooth, auto park assist and now Torque Pro !
Doubt you see this from the marketers.. Manufactures don't want people seeing this info but it's been available to them since EFI
pitrack_1
Torque Pro et al
Post by pitrack_1 » Thu May 08, 2014 1:48 am
There's a few holes, but overall Torque Pro is a very nice piece of work. It even has a 'HUD' mode- reverses the readout (R to L) for display by reflection off the windscreen.
My interface is on the blink (or I've damaged the plug/socket :shock:), see error below, so buying a new (better) one- should hopefully have SSM access/capability too. Will let you know how it goes.
Some info for you, RSR555:
  1. There have been a few instances (lots for me recently) of code U0073 (Network Error) being thrown. This can be cleared with Torque Pro, has been suspected it may even be caused by Torque Pro on occasion. Mine may be my interface failing. I have logged many Mb and hours without any issue previously. The symptom is the Christmas tree lights up, complete with flasher. You'll know what I mean when it happens :twisted:
  2. U0073 whist driving produces unpredictable results. Sometimes the performance is impeded, the steering may drop to a default (min) assistance level, lots of electronic bits don't work (including after recycling ignition) incl cruise, have had a rpm limit ~3000 once, seems to lose knock sensing/balancing at idle, etc.
  3. For when you're finding stuff in Torque Pro, storage directories are all over the place. Some I've found are (on a Nexus 7 2013):
    • /storage/emulated/0/.torque (various- config save files and logs)
    • /storage/emulated/0/.torque/tripLogs (for the GPS logs I think- GPS not activated by me)
    • /storage/emulated/0/torqueLogs (data logs, can include GPS readouts if specified I think)
    • /storage/emulated/0/torqueTrackLog.csv (seems to be a GPS dedicated log file)
  4. A Nexus 7 2013 seems it could fit nicely where the stereo (if it can be called that) unit is in a 2010 :-)
Patrick
Post by RSR 555 » Thu May 08, 2014 12:57 pm
Excellent pitrack_1 :)
I just got given a Nexus 7 tablet for helping a friend put his supercharger in his Nissan 350Z, so I will put this tablet straight to good use :cool:
Paul
pitrack_1
Nexus 7 and Torque Pro
Post by pitrack_1 » Thu May 08, 2014 10:38 pm
RSR 555 wrote:Excellent pitrack_1 :)
Hi Paul,
Well then here's a couple of files to get you started. Unzip the attached .zip, the two files inside for Torque Pro DPF monitoring are the dash setup and custom PIDs. Drop them in the appropriate directories under /storage/emulated/0/.torque/dashboards and /storage/emulated/0/.torque/extendedpids .
To do this, you'll need a file manager type program (free downloads) such as Ghost Commander (can send your logs to PC via Bluetooth) and File Commander (can act as a very basic music player- queue audio files, see below).
And the Nexus 7 (2013 or version 2) plugs nicely into the AUX-IN port (centre console bottom rear, underneath centre armrest on the 2010) to act as a music box too. You just need a standard stereo headphone socket (2.5mm?) male-male link cable.
Patrick.
Forester_DPF_Monitoring.zip
(2.62 KiB) Downloaded 714 times
Patrick
pitrack_1
100k
Post by pitrack_1 » Thu May 08, 2014 10:52 pm
Just achieved tonight...
Patrick
