Brumby EA82T turns itself off
Steve
Post by Steve » Sun Dec 29, 2013 6:10 pm
I recently purchased a Brumby with an EA82T fitted . Mostly it runs very well but twice now it has turned itself off while on the road. Each time I have been able to pull over without problems. It then restarts straight away and off I drive. What should I look at to try and solve this problem? Thanks, Steve.
Post by El_Freddo » Sun Dec 29, 2013 9:31 pm
G'day Steve,
Where to start on a purchased conversion? There could be so many issues, some that I can think of are:
- an immobiliser issue if there's one fitted
- an intermittent cut in power to the ECU
- an issue with the crank angle sensor - long shot, but the ECU may reset when you go to re-start the engine, thus ignoring the sensor issue or not having the issue since the reboot.
There could be a wiring issue or an earth issue that has become present in the system since the conversion.
One question - is the conversion running the stock ECU or an aftermarket ECU?
PS: welcome to the forum!
Post by steptoe » Mon Dec 30, 2013 7:11 am
And before any more help - some photos ! Have a look at the dizzy - does it have a vac can on its side ? Helps ID things - the series of EA82T - also the manifold and hitwire AFM or bigger flapper syle AFM ?
Post by Gannon » Mon Dec 30, 2013 10:22 am
Do the dash lights stay on (oil pressure, charge and ecs light) when it stalls or only after you turn the key back on?
Could be a dicky ignition relay
Post by RSR 555 » Mon Dec 30, 2013 1:49 pm
Gannon wrote:Do the dash lights stay on (oil pressure, charge and ecs light) when it stalls or only after you turn the key back on?
This was my first thoughts too.. I would like to know if you get any indications of things working or not working, i.e. tacho, fuel pump, etc
Steve
Post by Steve » Mon Dec 30, 2013 4:16 pm
Thanks for your replies. You have given me pointers to look for . I appreciate your quick replies as it has helped lower the stress level. Steve
Post by NachaLuva » Tue Dec 31, 2013 12:02 am
Steve wrote:Thanks for your replies. You have given me pointers to look for . I appreciate your quick replies as it has helped lower the stress level. Steve
Yeah dont stress mate, these guys are good at problem solving on the older Subies, as long as you can give them all the info they need ;)
