headlights on 92 Brumby
Heya folks
Hmmm I turn headlights on to low beam and "narda" but push the indicator stem forward for high beam and all 4 headlights light.
Is it a relay or what I ask.
Peter
Peter
2 of the 4 lights have twin filament bulbs, could be simple as 2 blown bulbs.
Are the lights the sealed or semi-sealed type?
and when you flick lever towards driver, high beam stays on ? Park light circuit work OK? I can confirm that high beam on 92 Brumby al four lights are ON. This is why you wanna get the steering wheel off. Light relays are under dash next to fuse panel ? aluminium silver cylindrical mounted in rubber, never seen one dead.
You gave me a glimmer of hope until I checked for power with my multi meter at the plug going to bubGannon wrote:2 of the 4 lights have twin filament bulbs, could be simple as 2 blown bulbs.
If twin filament should have power on 2 sides of the 3.....ie normal low beam and then other side when on high.
I have power at relay as below and trigger as well.... everything
I have a break in the feed powering low beam it appears or a plug after the relay has come apart.....weekend job if think
Steptoe might be able to confirm this as I have never actually worked on a brumby.
In the l series the lights are negatively switched, i.e. the common terminal of the light is +12v and the high and low switches earth the high and low filaments.
