2nd Hand Yank wrote:Thoughts?
My thoughts... well you asked for it.. STOP smoking that crack pipe !!
2nd Hand Yank wrote:I was wondering if anyone beside me thinks it could be a good idea.
Nope.. just you
2nd Hand Yank wrote:I have heavier-than-stock King Springs and like-new shockies from Guyph.
My car is rock-solid and hardly leans at all in corners at high speed,
despite the 2" body lift and 185/70R-14 tyres.
This is probably the case whilst they are new but after about 40,000kms or approx 2 years, this will change. Whilst going around one corner might not have a big rolling effect, this will change dramatically once you need to swerve a few times to miss object on the road.
2nd Hand Yank wrote:Reasons why I might want the swaybar gone:
extra wheel articulation
True, you will get 'extra' articulation but come on.. how much serious 4WDing are you doing that your front wheels are leaving the ground?
2nd Hand Yank wrote:a small benefit in weight savings.
Bwahahaha.. oh.. you're serious.. lol
You would save more weight running only half a tank of fuel.. you might not get to some places but at least you got that extra 0.0000001mpg
2nd Hand Yank wrote:Offroad reasons against taking off the swaybar?
Its located in front of the front axle shafts, so may provide a bit of bash protection.
Again.. what sort of 4WDing are you doing?
In closing, I think if you really are serious about taking your sway bar off for 4WDing, then just remove the bottom bolt (on each side of your swaybar to lower arm) before you go out and then reconnect after you've been out having fun.. this should take all of about 10mins to do each time.
Disclaimer: Not my website but
hyperlink here to Subaru workshop manuals
