compression on ej20g
woody.t
Post by woody.t » Mon Oct 24, 2011 12:13 am
what would be expected values for an ej20g on doing a compression... i think i remember being told ~150psi?
to do list:
H-top
Post by H-top » Mon Oct 24, 2011 3:57 am
150 to 165 is good for a turbo.
That is consistant with 8.5:1 CR
the number is less important, you
should look for all the cylinders being
the same or within 5Psi
H-Top
rolling in
Post by steptoe » Mon Oct 24, 2011 7:19 am
operating temp is also a consideration for comparison
Post by RSR 555 » Mon Oct 24, 2011 5:36 pm
Sounds about right but check the WSM and it will tell you the cold and hot readings.
Like H-Top has mentioned.. as long as the are withing cooee of each other then you'll be fine.
woody.t
Post by woody.t » Sun Oct 30, 2011 2:05 pm
can you do a compression test while the engine is out of the car.. like twist it over by hand or does it give lower readings..? with my reasoning i thought you'd be able to but the results i got on a wet and dry i really hope they're not an accurate depiction of the compression on the engine...
to do list:
Post by TOONGA » Sun Oct 30, 2011 2:30 pm
If you can connect the engine to a gearbox and install the starter motor then crank the starter motor you will get accurate readings.
turning the motor by hand or with a ratchet won't give you a compression reading it will give you a reverse of the leak down process.
woody.t
Post by woody.t » Sun Oct 30, 2011 3:43 pm
thats what i wanted to hear :D ahah
to do list:
