compression on ej20g
what would be expected values for an ej20g on doing a compression... i think i remember being told ~150psi?
to do list:
to do list:
Sounds about right but check the WSM and it will tell you the cold and hot readings.
Like H-Top has mentioned.. as long as the are withing cooee of each other then you'll be fine.
can you do a compression test while the engine is out of the car.. like twist it over by hand or does it give lower readings..? with my reasoning i thought you'd be able to but the results i got on a wet and dry i really hope they're not an accurate depiction of the compression on the engine...
to do list:
to do list:
thats what i wanted to hear
ahah
to do list:
to do list:
