Can you identify what these parts are, from these photos?
2nd Hand Yank
Post by 2nd Hand Yank » Sun Aug 07, 2011 11:43 am
I thought this would be a great place to ask what things are under my subaru's bonnet.
http://s92.photobucket.com/albums/l9/He ... tos010.jpg
^ It looks like the pre-heater equipment is intact, minus the hoses. Am I missing anything in the air-cleaner box?
http://s92.photobucket.com/albums/l9/He ... tos008.jpg
^ Here's where the pre-heater hose is supposed to be...
Makes me wonder if it'd be worth rigging up my own cold-air intake. :???:
Right now all it gets is hot under-bonnet air it seems.
See if you can look at 8 other photos I made into an album.
http://s92.photobucket.com/albums/l9/He ... ru%20pics/
1) What is this small white cylinder?
2) This appears to be the distributor, but there's something else almost identical
3) This is the distributor look-a-like. What is it really?
4) Top view of a mystery canister, sight glass
5) Side view of the "mystery canister"
6) This black cylinder on the firewall... is it a solenoid? what does it do?
7) A spare electrical connector! What does it look like it's for? Can I add driving lights with this? :D
#8 Towards the bottom left you see the hole that is probably for EGR, with the conneting hose missing. Would I need a hose to pass rego in a different state, if I want to move?
phantomD
Post by phantomD » Sun Aug 07, 2011 1:21 pm
The mystery canister with the sight glass is the receiver-dryer for your air conditioning system. Your "distributor look-a-like" is the charcoal canister for emissions. The black cylinder on the firewall is actually your windscreen wiper motor. The white cylinder (small) in the first photo is your fuel filter I think???
Post by El_Freddo » Mon Aug 08, 2011 12:56 am
Only thing I can see missing there is the lid :rolleyes:
^ You just need the chunky flexi hose that joins the two here. Hot under bonnet air is not a bad thing in winter! Summer it will be but most will still run ok like this...
The white cylinder is your vacuum reservoir for you cabin air ducting etc.
This is your distributor with the coloured dots on the wires that clip into the top of the dizzy cap. The next pic in the album is as Phantom D says - charcoal canister for emissions gear.
Next two album pics are as Phantom says - AC gear.
This is the wiring for your gauges and the power to the solenoids on the carbie - anti dieseling and most likely the auto choke too I think.
I don't know what you're looking at here - but this is where the spare wheel goes! Yep, under the bonnet... RACV guy once told me it would have been the last place he looked!
Tip: To display images you simply copy the "IMG code" and drop it in here. It will look like this [IMG]http://i92.photobucket.com/albums/l9/He ... tos009.jpg[/*IMG] <- but without the * in the last square brackets...
tony
Post by tony » Mon Aug 08, 2011 11:50 am
the last pic the hole is for the carby preheater hose you will need it in really cold weather and to pass registration. it goes to the bottom of the air cleaner
it is a sort of corrugated pipe. I used an air con ducting one but it melted off. not really necessary in west australia the lever thing on the air cleaner for summer/winter running is fed by this.
phantomD
Post by phantomD » Mon Aug 08, 2011 10:26 pm
Really? Does a Brumby have this?
Post by guyph_01 » Mon Aug 08, 2011 10:33 pm
Just wandering,
I have removed mine from my L series and hooked the vac line straight to a vac outlet on the manifold. Is this ok, bad or better? should i put the reservoir back?
th
Post by El_Freddo » Tue Aug 09, 2011 12:23 am
phantomD wrote:Really? Does a Brumby have this?
Not that I can remember, but I think the only vacuum hose needed in those is for the cabin air recirculation... I could be wrong though as I don't really remember!
guyph_01 wrote:Just wandering,
Why did you remove it? I don't know what it would do but you might find your revs could drop at idle if you change the settings in the cab... But really I don't know - leave it for now and if you find the engine doing strange things when you change the air settings then put it back :???:
2nd Hand Yank
Post by 2nd Hand Yank » Wed Aug 10, 2011 12:09 am
tony wrote:the last pic the hole is for the carby preheater hose you will need it in really cold weather and to pass registration. it goes to the bottom of the air cleaner
So the carb preheater is fed by heated air beside the exhaust?
I need some type of flexible metal ducting to connect it without melting?
So you think somewhere like Bunbury,
I'm doing reasonably well without it?
Bunbury is probably like Sydney for winter cold.
Our worst winter mornings are still 2-5 C, most winter mornings are 6-10 C.
2nd Hand Yank
Post by 2nd Hand Yank » Wed Aug 10, 2011 12:12 am
So the short distance missing hose to the airbox is for regular fresh (cold) air to the air cleaner?
I'm wondering if it might be worth it rigging up my own cold-air induction,
with a switch to set it to pre-heated air when it's cold.
Or perhaps I should just put it back to factory settings? :p
2nd Hand Yank
How do I loosen this roof-rack screw/bolt?
Post by 2nd Hand Yank » Wed Aug 10, 2011 12:13 am
It doesn't look like a regular spanner or socket would fit over that. :???:
I would like to be able to adjust my roof rack spacing.
http://s92.photobucket.com/albums/l9/He ... nOz006.jpg
When I do the [IMG] thing as Bennie suggested,
all that ends up when I post is a blank space.
I did it exactly as you did it, but it doesn't work for me.
Perhaps it's my membership status?
Post by El_Freddo » Wed Aug 10, 2011 5:33 am
2nd Hand Yank wrote:So the carb preheater is fed by heated air beside the exhaust?
Yep - there's a foil type hose you can get and a good parts joint should carry some in stock. I think you'll find that if you don't install one that your cold morning running will be crap and engine warm up might take a little longer too.
2nd Hand Yank wrote:So the short distance missing hose to the airbox is for regular fresh (cold) air to the air cleaner?
Factory settings would be easier - the air pick up is behind the driver's bumper bar indicator so it'd be sucking fresh air anyway. A switch would be interesting but if you've got the winter/summer setting in the right spot you should be ok.
2nd Hand Yank wrote:Image
Yeah they like to be painful like that. I don't know where you'll get a socket to fit it, you might get lucky if you send an online tool website an image explaining what you're after.
OR it could be a plastic clip that holds the cover on - my rolla racks have one but is accessible by fingers. You might be able to turn it with a set of long nose pliers.
2nd Hand Yank wrote:http://s92.photobucket.com/albums/l9/He ... nOz006.jpg
Not membership status - you've copied the url of the image when it's displayed in large format - so there's coding in the url that the display tag doesn't understand - In the third quote box the top code is what you tried to display, the one below is the one to display the image - I've added the "*" to make the coding show as text for this example. Then the image displayed without the "*" in the code.
Once you nut out where/how to get the code you'll be a pro at posting pics! Here's how you do it: On the right of the large single image (and when cursor is on an image in the "view all" mode a drop down window appears) there's a panel with several codes - you want the IMG one, click (it copies itself) then paste where you want it in your text. I've done this in your quote above ;)
pitrack_1
Post by pitrack_1 » Tue Aug 16, 2011 1:44 am
Hey 2nd Hand Yank,
I've used your pic http://s92.photobucket.com/albums/l9/He ... tos010.jpg in a new thread I started, as it provoked a memory. See "A Dusty Tale"
Hope you don't mind,
Patrick
Ex- 2010 Forester Diesel
2nd Hand Yank
Post by 2nd Hand Yank » Tue Aug 16, 2011 8:46 am
pitrack_1 wrote:Hey 2nd Hand Yank,
No worries mate. :)
