GOD wrote:Not only are they allowed to be wired with the high beams, they must be. The idea is that wherever you'd have high beam off, the driving lights are off as well so they don't blind anyone. Then when you've got the road to yourself, flick all the lights on.
I've just never seen them used on the road before. Maybe because I'm a city-boy? I like being in the country though.
Yes, bright lights will blind, confuse and sometimes stop a kangaroo. But that's the roo's problem, not mine - I'd rather have as much light as possible, then work on dodging or flattening (depending on which car I'm in) whatever beasts may appear.
Good point; better they stay put so you know what they're doing.
Do any "driving lights" put out light sideways, maybe a 45 degree angle from your direction? I'd like to be able to see 10-20 m either side of the road. It would also help when you turn the wheel. I find it kinda dumb that the automotive industry's standard is to not provide a driver much of a view at night while turning a corner.
Both. The idea is to use the standard wiring to trigger a new relay, which switches nice, new, good quality power wires to the lights. There are instructions floating around if you're not sure.
It'd be interesting to see if that's already been done. My subi has quite a few modifications. The radiator and A/C condensor is protected with "fly-screen" behind the stock grill. I didn't see that on the other L Series I looked at.
I was more thinking about keeping the odd size away from the steering, brakes and powered diff. Probably doesn't make a lot of difference.
So you mean having tyres on the rear being larger than on the front?
Does anyone here do that? I'm wondering what's the advantage, since the back end is lighter... unless you pull trailer a lot. Hmm...
Wheels hanging outboard of the guards is due to the offset (backspacing) of the commonly available 14" wheels. You'll have the same problem with any size tyres on those rims. Get rubber flares to make it all legal.
More shopping from 4wd shops?
4wd accessory shops. Or maybe you could make one if you're a master seamstress
Ah, so they can be bought.
Show us some pics of the car, including the lift kit. It'll probably be a 2" body lift. Suspension lifting is uncommon with these cars.
Dane.
I'll try to get around to it sometime soon.
