H-top
Post
by H-top » Tue Jan 11, 2011 10:58 am
G'day all,
I'm having trouble removing the stubs from a R160.
I've undone all I can see but I can't pull them out?
Samuel
H-Top
rolling in
rtcb65
Post
by rtcb65 » Tue Jan 11, 2011 11:33 am
Have you undone the torx bolts in the stub axles themselves.
rtcb65
Redneck Rick.
H-top
Post
by H-top » Tue Jan 11, 2011 11:47 am
Where are these torx hiding?
Legacy 4.11 diff btw
H-Top
rolling in
Post
by El_Freddo » Tue Jan 11, 2011 11:49 am
rtcb65 wrote:Have you undone the torx bolts in the stub axles themselves.
I used an 8mm deep socket to get mine out. I got a supercrp $11 deep socket kit, decided if I broke the socket it wasn't the end of the world. Once you have these bolts out the stub axle should easily pull out from the diff...
H-top
Post
by H-top » Tue Jan 11, 2011 12:13 pm
Down the centre of the stub?
H-Top
rolling in
Post
by El_Freddo » Tue Jan 11, 2011 12:22 pm
H-top wrote:Down the centre of the stub?
Yes, that is correct. Without removing these bolts you've got not chance of removing the stub axles...
H-top
Post
by H-top » Tue Jan 11, 2011 1:02 pm
glad i didnt use any violence! cheers team!
H-Top
rolling in
rtcb65
Post
by rtcb65 » Tue Jan 11, 2011 1:29 pm
H-top wrote:Where are these torx hiding?
Being a 4.11 , are you sure it a male shaft. If it is , there should be a hole in the centre of the shafts. At about level with the seal but inside the shafts, there is a torx bolt.
rtcb65
Redneck Rick.
90brumby
Post
by 90brumby » Tue Jan 11, 2011 2:23 pm
If there is no hole in the stub. The rs liberty uses c clips to hold the stubs in. I used a old cv joint and put it on my slid hammer
Tristan
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
ScubyRoo
Post
by ScubyRoo » Tue Jan 11, 2011 4:04 pm
I used an angle grinder and turned it into a female
. Lifted, bars, exhausts... View
Gumtree ad
H-top
Post
by H-top » Tue Jan 11, 2011 5:43 pm
I'm at home defending my place
from the floods ATM
will confirm all when I get back go the shop
cheers
H-Top
rolling in
Phizinza
Post
by Phizinza » Tue Jan 11, 2011 8:43 pm
El_Freddo wrote:I used an 8mm deep socket to get mine out.
When I tried with a normal socket I rounded the bolts. Ruined the stubs getting them out.
So next time I needed to remove them from another diff I bought a small 1/4" socket Torx Deep E socket set from the UK with the E10 socket for $50 odd.
H-top
Post
by H-top » Wed Feb 02, 2011 7:20 pm
No torx in the stubs?
Where next?
H-Top
rolling in
FujiFan
Post
by FujiFan » Wed Feb 02, 2011 7:33 pm
Just had a look at an R160 happen to have close to me (Open not LSD), appears to have some kind of tamper proof bolt, similar to torx.
- R160sideon 002.jpg (44.51 KiB) Viewed 4724 times
H-top
Post
by H-top » Wed Feb 02, 2011 7:50 pm
unfortunately it is nothing like that.
there is a 4x5mm hole in the center with nothing in it!
must be clips somewhere?
S
H-Top
rolling in
FujiFan
Post
by FujiFan » Wed Feb 02, 2011 7:56 pm
Got me
90brumby
Post
by 90brumby » Wed Feb 02, 2011 11:07 pm
use a inner cv joint put the roll pin back in and connect a slide hammer and the stub should come out in 2 or 3 hits or even a pry bar between the diff and joint that u have refitted and pry the shaft out
if this makes sence
Post
by El_Freddo » Thu Feb 03, 2011 8:32 pm
Phizinza wrote:When I tried with a normal socket I rounded the bolts. Ruined the stubs getting them out.
Sorry I should have said a hex 8mm deep socket...
H-top
Post
by H-top » Thu Feb 03, 2011 10:07 pm
I don't have that in my stubs
H-Top
rolling in
Post
by El_Freddo » Sat Feb 05, 2011 12:54 am
H-top wrote:I don't have that in my stubs
Can we get some pics of the diff and stubs H-top as we're either talking about different diffs or something funky is going on...
