How to remove R160 Male Stubs
H-top
Post by H-top » Tue Jan 11, 2011 10:58 am
G'day all,
I'm having trouble removing the stubs from a R160.
I've undone all I can see but I can't pull them out?
Samuel
H-Top
rolling in
rtcb65
Post by rtcb65 » Tue Jan 11, 2011 11:33 am
Have you undone the torx bolts in the stub axles themselves.
rtcb65
Redneck Rick.
H-top
Post by H-top » Tue Jan 11, 2011 11:47 am
Where are these torx hiding?
Legacy 4.11 diff btw
H-Top
rolling in
Post by El_Freddo » Tue Jan 11, 2011 11:49 am
rtcb65 wrote:Have you undone the torx bolts in the stub axles themselves.
I used an 8mm deep socket to get mine out. I got a supercrp $11 deep socket kit, decided if I broke the socket it wasn't the end of the world. Once you have these bolts out the stub axle should easily pull out from the diff...
H-top
Post by H-top » Tue Jan 11, 2011 12:13 pm
Down the centre of the stub?
H-Top
rolling in
Post by El_Freddo » Tue Jan 11, 2011 12:22 pm
H-top wrote:Down the centre of the stub?
Yes, that is correct. Without removing these bolts you've got not chance of removing the stub axles...
H-top
Post by H-top » Tue Jan 11, 2011 1:02 pm
glad i didnt use any violence! cheers team!
H-Top
rolling in
rtcb65
Post by rtcb65 » Tue Jan 11, 2011 1:29 pm
H-top wrote:Where are these torx hiding?
Being a 4.11 , are you sure it a male shaft. If it is , there should be a hole in the centre of the shafts. At about level with the seal but inside the shafts, there is a torx bolt.
rtcb65
Redneck Rick.
90brumby
Post by 90brumby » Tue Jan 11, 2011 2:23 pm
If there is no hole in the stub. The rs liberty uses c clips to hold the stubs in. I used a old cv joint and put it on my slid hammer
Tristan
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
ScubyRoo
Post by ScubyRoo » Tue Jan 11, 2011 4:04 pm
I used an angle grinder and turned it into a female :D
H-top
Post by H-top » Tue Jan 11, 2011 5:43 pm
I'm at home defending my place
from the floods ATM
will confirm all when I get back go the shop
cheers
H-Top
rolling in
Phizinza
Post by Phizinza » Tue Jan 11, 2011 8:43 pm
El_Freddo wrote:I used an 8mm deep socket to get mine out.
When I tried with a normal socket I rounded the bolts. Ruined the stubs getting them out.
So next time I needed to remove them from another diff I bought a small 1/4" socket Torx Deep E socket set from the UK with the E10 socket for $50 odd.
H-top
Post by H-top » Wed Feb 02, 2011 7:20 pm
No torx in the stubs?
Where next?
H-Top
rolling in
FujiFan
Post by FujiFan » Wed Feb 02, 2011 7:33 pm
Just had a look at an R160 happen to have close to me (Open not LSD), appears to have some kind of tamper proof bolt, similar to torx.
R160sideon 002.jpg (44.51 KiB) Viewed 4742 times
H-top
Post by H-top » Wed Feb 02, 2011 7:50 pm
unfortunately it is nothing like that.
there is a 4x5mm hole in the center with nothing in it!
must be clips somewhere?
S
H-Top
rolling in
FujiFan
Post by FujiFan » Wed Feb 02, 2011 7:56 pm
Got me :confused:
90brumby
Post by 90brumby » Wed Feb 02, 2011 11:07 pm
use a inner cv joint put the roll pin back in and connect a slide hammer and the stub should come out in 2 or 3 hits or even a pry bar between the diff and joint that u have refitted and pry the shaft out
if this makes sence
Post by El_Freddo » Thu Feb 03, 2011 8:32 pm
Phizinza wrote:When I tried with a normal socket I rounded the bolts. Ruined the stubs getting them out.
Sorry I should have said a hex 8mm deep socket...
H-top
Post by H-top » Thu Feb 03, 2011 10:07 pm
I don't have that in my stubs :(
H-Top
rolling in
Post by El_Freddo » Sat Feb 05, 2011 12:54 am
H-top wrote:I don't have that in my stubs :(
Can we get some pics of the diff and stubs H-top as we're either talking about different diffs or something funky is going on...
