Lifter Ticking Noise
suba88
Post by suba88 » Wed Oct 19, 2005 6:38 pm
Is there any other product that can stop the lifters from "ticking" in the EA82.
I have used SuperX before and this worked really well but the place i bought it from is ordering the next lot from America. Just asking if anyone else has tried different products.
paul
tim_81coupe
Post by tim_81coupe » Wed Oct 19, 2005 9:54 pm
I used the Nulon Lifter free stuff, we sell it at my work. It's crap and I won't sell it to anyone after using it.
Super X all the way.
Fang
Post by Fang » Thu Oct 20, 2005 5:37 am
I had a similar experience - the SuperX worked for a while - then it came on back. I had a mechanic tell me to use the Wynn's version - but the same thing - went away, came back.
Ended up having oil pump seals, crankshaft seals, etc replaced at the front of the motor. I think the mechanic also used a thinner oil too - I have no lifter tick at all anymore.
I believe there is no more annoying noise in a car than lifter tick! :x
BlackMale
Post by BlackMale » Thu Oct 20, 2005 10:28 am
You could also try changing your oil brand (depending on what you are using now) to a thicker/less viscous oil
Kev
Post by Kev » Thu Oct 20, 2005 10:54 am
This problem has been on this forum many times.
The usual cures I have seen are:
1. Replace the oil pump seals. They are available as a kit.
2. Use a less viscous oil. Most oils are 20w50, look for a 15w40 oil.
Kev
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Oct 20, 2005 1:49 pm
As above but if they have been noisy for a while they may need cleaning out by pulling them apart, there is a page here http://homepage.powerup.com.au/~camncat ... er_fix.htm
suba88
Post by suba88 » Thu Oct 20, 2005 2:43 pm
Where abouts can you get a kit for the oil pump seals?
That seams like the best option, because i have used Super X before and it did work for quite a while and just recently the ticking has come back.
Thanks paul
BlackMale
Post by BlackMale » Thu Oct 20, 2005 4:12 pm
Paul for us over here in the west Tim is ya man. If he can not get it then just go without (or make a trip to Qld) :lol:
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Oct 20, 2005 4:14 pm
Subaru is the best place to get them, they arent expensive either less than $40 last time i brought a kit. While you are in that area if you havent changed your cam belts it would be a good time to do that and the main and cam seals.
stamp_licker
Post by stamp_licker » Thu Oct 20, 2005 7:36 pm
i paid about $30 for the o ring kit about 4 weeks ago.if your car has done alot of km you can put another oilpump rotor in about $50.i have spent about $400 on my old ea trying to get rid of the tick.the funny thing is when i swapped motors and then put the old one back in again :evil: it hasn't ticked since going back in. jealous i guess
Building a hardcore postie:D
