rear wiper L SERIES sedans ??
Loking through my factory manuals I see a diagram of L Series sedan with its wiring diagram and lists a rear window wiper. Which market got these? I imagine it would be a hole in the window job to fit it.
pretty much everywhere except for aus haha...i know the us and japan had them.
just like every other import sedan of any manufacturer seems to have a rear wiper.
Its probabily for the coupe's rear wiper. I'd say that subaru would use a standard sedan wiring loom for the coupe, so they add everything into it for one generic loom...
It would be interesting if you could check out the loom on your coupe T'subaru to see if there's a set of plugs for the rear doors so the dash can display the door as being open if the switches were in place as they would be in the sedan...
The jap market had it.
Sedans definitely came with it. All the locating points are there. If you look under the parcel shelf in the middle, there is a kind of a bump with threaded holes - thats where the motor went. The rubber plug covered hole at bottom right corner of the boot opening (under the lid) is for the rear washer bottle.
Australian delivered sedans do not have the wiring in the loom. The wagons do though (its the same for sedans and wagons).
Ah YES. I recall that bump and welded nuts. Another bloody practical option we missed out on. An old boss of mine had an office and a girlfriend in Japan - should have been on better talking terms with him. A Japanese spec'd RX sedan would have been intereting....though he did say you never see old stuff on the roads over there - all those exported must be stashed somewhere out of sight - maybe in NZ!
- T'subaru
Will do Bennie, but wont be home until this Friday eve.El_Freddo wrote:Its probabily for the coupe's rear wiper. I'd say that subaru would use a standard sedan wiring loom for the coupe, so they add everything into it for one generic loom...
- T'subaru
Hi Bennie,El_Freddo wrote:Its probabily for the coupe's rear wiper. I'd say that subaru would use a standard sedan wiring loom for the coupe, so they add everything into it for one generic loom...
Yes I have rubber booted door switchs on my RX 3 door. It illuminates a red diagonal led on the dash indicating either drivers or passenger door is open, but nothing on the rear hatch. I can post schematics of electrical on any of the '89 models from fsm if helpful.
Cheers, Mark
- T'subaru
Hey Bennie, may have misunderstood but coupe..im thinking 2 door and sedan 4 door...and you mentioned rear doors and coupe??El_Freddo wrote:Its probabily for the coupe's rear wiper. I'd say that subaru would use a standard sedan wiring loom for the coupe, so they add everything into it for one generic loom...
Cheers..let me know
Mark
- T'subaru
door open display is used on my '90 wagon, all doors, RX both doors, 93 Loyale all doors, and i believe '86 gl all doors..although its digi and when first drug home i slipped battery in to see if dash worked...didnt take it any further than that.
Mark
