totally stumped!
Post by El_Freddo » Mon Feb 15, 2010 8:34 pm
steptoe wrote:Huh? No TPS? on L Series NA MPFI? Throttle Position Sensor? You sure Bennie?
SORRY! Skim reading - read it as KNOCK SENSOR - the MPFI DOESN'T have one... :oops: :oops: :oops:
Post by steptoe » Mon Feb 15, 2010 11:23 pm
Waiting to hear some positive news soon....
Post by El_Freddo » Tue Feb 16, 2010 12:17 pm
steptoe wrote:Waiting to hear some positive news soon....
x2! I'll also be keen to know how hard it goes - then how long it lasts being an NA motor with the turbo.
twilightprotege
Post by twilightprotege » Tue Feb 16, 2010 2:09 pm
the NA MPFI definately has a TPS - it's a variable tps rather than an on-off one like the 3 pluggers
Post by steptoe » Tue Feb 16, 2010 4:01 pm
So...we need the TPS and AFM to suit the computer in use, was gonna suggest that you try the four plug dizzy if your car is four plugger just to see if it resolves your drama that we/ I may have helped you create
twilightprotege
Post by twilightprotege » Tue Feb 16, 2010 4:12 pm
yeah. afm, tps and dizzy all need to match the ecu, rest not so much.
will be putting on the turbo IM and other stuff in the morning. give it at least 24 hours to settle, then filling it up with coolant and seeing how i go.
Post by El_Freddo » Tue Feb 16, 2010 4:46 pm
twilightprotege wrote:yeah. afm, tps and dizzy all need to match the ecu, rest not so much.
I'll be hanging to hear how it goes!
All the best.
twilightprotege
Post by twilightprotege » Tue Feb 16, 2010 6:52 pm
thanks. i'm hanging to hear how it goes too! lol
twilightprotege
Post by twilightprotege » Thu Feb 18, 2010 7:03 pm
update
engine started today, except only on 3 cylinders....
my fault though - i wacked the dizzy cap while putting the IM back on and knocked cylinder 3 off. have got a cap and rotor on order, so will see how that goes then. that probably wont come until monday unfortunately :( assuming they ordered the right one - the 3 plug one is different to the 4 plug one.
no leaks though...lol
Post by El_Freddo » Thu Feb 18, 2010 7:50 pm
Bugger about the cap - at least you got it started! Did it have any trouble trying to start on three cylinders? If it didn't really I reckon its a goer with the new cap!
twilightprotege
Post by twilightprotege » Thu Feb 18, 2010 8:38 pm
it kind of did once i screwed the idle adjustment screw out further. will surely have to adjust the timing once i get that dizzy back working
Post by steptoe » Fri Feb 19, 2010 8:02 am
GH617 cap GH605 rotor for my three plug dizzy 86 model EA82T - check with them?
twilightprotege
Post by twilightprotege » Fri Feb 19, 2010 9:50 am
yep those are the numbers i ordered. yay! finally something going right for me
twilightprotege
Post by twilightprotege » Thu Feb 25, 2010 6:44 pm
she lives!!!!!!!!!!!!!!!!!!
and it goes very very well. i set the timing to 10 degrees BTDC and it idles nice and smoothly about 800rpm. definately the best the car has ever gone.
there were some ever so slight misses as it revs along, so i'm going to double check the spark plug gaps and make sure they are pretty small, probably about 0.8mm, to make sure the mixture goes boom.
very very impressed with it indeed.
H-top
Post by H-top » Thu Feb 25, 2010 7:03 pm
Congrats! Glad it's going somewhere lol
H-Top
rolling in
Post by AlpineRaven » Thu Feb 25, 2010 7:24 pm
Congratulations!!!
twilightprotege
Post by twilightprotege » Thu Feb 25, 2010 9:21 pm
oh and i've lost one of the warming codes too. before this engine I was getting 45 and 51. now i'm only getting 45.
just got to get the slight studdering under acceleration and it'll be sweet.
is this the only high compression turbo ea82 going around oz? or even the only one attempted?
Post by steptoe » Thu Feb 25, 2010 11:06 pm
there are the bits in my shed.... GREAT NEWS. Musta been pooey cap and rotor
whens yer boost light come in, whats boost max at, just how much better and where?
Post by Gannon » Fri Feb 26, 2010 5:27 am
So what ECU are you running? Shouldnt your timing be set to 20deg?
Good to see its running. You should dyno it to see how much power its making
Post by steptoe » Fri Feb 26, 2010 8:40 am
reduced timing due to increae of CR from EA82T 7.7:1 to mpfi 9.5:1, increasing CR by 23% !! Before turbo gets spooling!! Old school is reduce intial timing to start with as you increase comp ratio. ten is easy to remember
He is running 3 plug ECU, dizzy and separate knock box - all 3 plug stuff
Return to “Trouble Shooting”
