Who may have an EA82 Turbo or parts for one?
So, yeah, the old girl was pulled-down today, the block and one piston is stuffed, and I need some parts, or even a complete EA82T motor, does anyone have some? cheers....
If they are similar i have a ea82 MPFI non turbo...
- phillatdarwin
have a look hear
showthread.php?t=10672&highlight=sale
vbclassified.php?do=ad&id=79
it wood be all u need .
that is cheap for a inport as if u can get one out of Japan it will cost u around $1300 last time I look about 3months back .
- phillatdarwin
No, but the thread in the block should still be there, and if it isnt, just drill and tap it outnncoolg wrote:...do the MPFI's have a knock sensor?
What do you mean by 2port heads? Im not sure. All i know its a EA82 MPFI 2nd gen. Is supposed to be blown head gasket. When i got the car i just took it out and replaced it with the EJ22. I only have the "passenger" head left and Passenger side pistons, as the Driver side ones are a bit rusty now:s... Only if interested i can remove and send pics.
Well mine is MPFI engine...
- phillatdarwin
That breather pipe at the back of the RHS block with its baffle plate in the bell housing is not unique just to the turbo motors, but all MPFI EA82 blocks I believe. In my thinking in using carb block with efi heads myself I figured the ID of the rocker breathers is more than enough as all new motors use much smaller breather hose ID's. Just two does alright for carby, why does mpfi need an extra? Just for the faster engine speed of the turbo ? so what is the excuse for the NA mpfi then ? As a back up I was intending to tap another breather into the steel oil filler tube. Easy to do, access or replace if one stuffs up first prototype
