Where can I get decent EA82 efi/turbo heads?
nncoolg
Post by nncoolg » Mon Sep 07, 2009 5:34 pm
Im after a set with no cracks accross the combustion chamber, between the valves. A want a left & right in good nick, it's okay if they need re-surfacing though.
Pref. Gen 3 ones, but Gen 2 will do, Gen 1 only as last resort.
Can anybody help?
Thanks.
Post by Gannon » Mon Sep 07, 2009 6:41 pm
MPFI heads are your best bet. Just have to drill and tap the oil and coolant ports
H-top
Post by H-top » Mon Sep 07, 2009 7:58 pm
Any pics on where to drill? Cheers
H-Top
rolling in
Post by Gannon » Mon Sep 07, 2009 9:35 pm
You will need some turbo heads to copy, as you will have to get the correct thread pitch for the turbo oil feed, and use the metal pipe from the oil return
phillatdarwin
Post by phillatdarwin » Mon Sep 07, 2009 10:05 pm
can buy out of the usa as a new cast for about $250us
http://cgi.ebay.com/ebaymotors/85-90-1- ... ccessories
this is for a full gasket set.for this the post was $38us
have a look at ebay posting as i posted it there about 2 mounths
phillatdarwin
Post by phillatdarwin » Mon Sep 07, 2009 10:58 pm
Post by Gannon » Mon Sep 07, 2009 11:25 pm
Note that those eBay.us heads are marked as Single point fuel injected, not multipoint fuel injected, which is what is needed for turbo.
Post by guyph_01 » Tue Sep 08, 2009 12:36 am
hi i have a ea82 MPFI head (passenger) side one still on the block. I sold the other side already. Let me know if you want it. And i'll remove it and check if its still ok. send some pics etc.
nncoolg
Post by nncoolg » Tue Sep 08, 2009 6:01 am
...If only you still had the pair! Xtremerx has a set, still waiting for all the details, but I need all the avenues in case I can't get those... I really dont want to buy just one willy-nilly, on the off chance that I could find it's brother aswell.
Post by guyph_01 » Tue Sep 08, 2009 9:47 am
well let me know what you decide.
nncoolg
Post by nncoolg » Tue Sep 08, 2009 4:13 pm
So, is everything else the same on the EFI heads, just the oil feed line and coolant feed line? what about the oil return pipe? Has anybody actually used these kind of heads on an EA82 Turbo, or is it just here-say?
phillatdarwin
Post by phillatdarwin » Tue Sep 08, 2009 10:52 pm
i have Sean new cast ones on ebay before cast in the usa and thay wear ea82t heads
seagull
Post by seagull » Wed Sep 09, 2009 12:29 am
west coast imports in Perth Malaga has a low k ea82 turbo motor on there shelf
nncoolg
Post by nncoolg » Wed Sep 09, 2009 6:55 pm
do you know if they are still available from subaru?
the ones from the states, they must be reco'd yeah?
phillatdarwin
Post by phillatdarwin » Wed Sep 09, 2009 7:15 pm
the one i fond wear new cast ally the link i put upis for recon head
