interior light in brumby not working on 'door' setting
kona480
Post by kona480 » Mon Jul 13, 2009 12:44 pm
Hi
does anyone know what the problem could be? And how can I fix it?
thanks
kndkris
Post by kndkris » Mon Jul 13, 2009 2:22 pm
i have the same problem in my lib, not sure how to fix though?
rtcb65
Post by rtcb65 » Mon Jul 13, 2009 4:23 pm
Check the door switch. Most i have come across , get a little rust on them which stop them from contacting properly. Also check the wires that connect to the light it self, sometimes they just need to be pulled out and put back in a couple of times to get a better contact.
rtcb65
Redneck Rick.
Rocksy
Post by Rocksy » Mon Jul 13, 2009 5:06 pm
i have the same issue, my alarm also has trouble because of the stupid door switch.
Post by TOONGA » Mon Jul 13, 2009 5:32 pm
an amp meter and a bit of patience is whats required here which is why my brumby still has no interior light (a yellow sticker offence in WA if the cop is cranky)
but as said 99% of the time its a contact problem the other 1% its a blown globe
with the alarm not working it is a simple fix I was told to put a small capacitor in with the light to boost the signal when the door opens, mind you you must put it in the right way otherwise you get a nice pop when it overheats and explodes (amp meter will help you work that out)
if you ask a technician at an alarm place he might tell you how to go about it more often than not they want to charge money
kona480
Post by kona480 » Mon Jul 13, 2009 6:39 pm
the light works when you turn it on, just not on the door setting
RX Coupe
Post by RX Coupe » Mon Jul 13, 2009 6:58 pm
I had the same problem with my Brumby. Went down to U-Pull it and got two better design switches off an MY sedan and no more problems.
Cars: 02 Subaru Outback
85 Subaru RX Turbo Coupe (sold)
92 Subaru Brumby (sold)
Post by AlpineRaven » Mon Jul 13, 2009 9:44 pm
Common problem with aged cars, I remembered I used to have the problem with my Camira once, I just replaced whole switch to another one, it was a dirty contact from open & closing many times..
Post by TOONGA » Mon Jul 13, 2009 10:10 pm
kona480 wrote:the light works when you turn it on, just not on the door setting
either the switch in the light is buggered or the switches in the doors are stuffed
kndkris
Post by kndkris » Tue Jul 14, 2009 9:48 am
I have tried 3 different units in my lib, multiple globes, works when its set to on but not when any of the doors open, which would suggest a wiring issue somewhere, maybe alarm related.. boot light is the same.
