brumby talk
Post by El_Freddo » Wed Sep 28, 2011 3:34 pm
mud_king91 wrote:Yup coloured it myself cant ya tell
Gold star for you boy!!
Keep up the good work ;)
mud_king91
Post by mud_king91 » Thu Sep 29, 2011 7:26 pm
how does the twin carb set up work like is it a certain manifold or is it possible to conjure something simliar to what I4,s use with the quad carb ?
Post by El_Freddo » Fri Sep 30, 2011 6:49 pm
mud_king91 wrote:how does the twin carb set up work like is it a certain manifold or is it possible to conjure something simliar to what I4,s use with the quad carb ?
It's a particular manifold. But you could pioneer a custom twin carb setup like the VWs have :twisted:
Apparently to get the most out of the twins you need the twin port heads and cam to match. But I think they would be an improvement over the stock single carb setup.
mud_king91
Post by mud_king91 » Fri Sep 30, 2011 7:02 pm
ok well my ingenious mind has decided that the plans for a hydrogen generator i just bought shall be powerful enough to run a small subaru engine (EA) on nothing but hydrogen... should make for a very cheap car to run
Post by El_Freddo » Fri Sep 30, 2011 7:11 pm
mud_king91 wrote:ok well my ingenious mind has decided that the plans for a hydrogen generator i just bought shall be powerful enough to run a small subaru engine (EA) on nothing but hydrogen... should make for a very cheap car to run
I'm VERY keen to see how this ends.
mud_king91
Post by mud_king91 » Fri Sep 30, 2011 7:18 pm
well with a scientist for uncle and a mechanical genius for the erm well me hahaha it should work its just funds im thinking for now i might just buy a cheap piece of c#@p 4x4 subaru for now... btw did they ever come out in a SPFI version or was it MPFI and carburettor only ?
Post by El_Freddo » Fri Sep 30, 2011 7:22 pm
mud_king91 wrote:btw did they ever come out in a SPFI version or was it MPFI and carburettor only ?
Brumbys never came out in either.
The L series came out in MPFI and and carbie in Australia. America got the SPFI EA82, and this is a common conversion on the EA81 with good results. It's basically all factory but with the EA81 block.
mud_king91
Post by mud_king91 » Fri Sep 30, 2011 7:25 pm
ah ok its just carbs sieze up if used with out oil based fuel so its hard to run hydrogen through it constantly if i could get my hands on a SPFI manifold it,d make life a billion times easier or i pull off the carby and replace it with a modified throttlebody... idk well see how much hydrogen i need to power it first
Brumby Kid
Post by Brumby Kid » Fri Sep 30, 2011 7:33 pm
When the hydrogen conversion is done, if it is done. I am soo there, love my science and would love to see how it runs! In principle its all good. Finding a hydrogen fuel supply ie a servo, that could be hard!
Cam
Dads Car: 02 Impreza WRX STi
mud_king91
Post by mud_king91 » Fri Sep 30, 2011 7:41 pm
1L distilled water+ 1 spoon of bi carb soda
Post by El_Freddo » Fri Sep 30, 2011 7:46 pm
mud_king91 wrote:ah ok its just carbs sieze up if used with out oil based fuel
I'm not sure about this, what about all those LPG converted cars? I know we never ran fuel through the carb, and this was only an issue when trying to run on fuel as the rubber O seals etc had dried out...
mud_king91 wrote:1L distilled water+ 1 spoon of bi carb soda
Is that it? I thought bi carb and water created carbon dioxide... But I never did chem so don't know anything really!
Brumby Kid
Post by Brumby Kid » Fri Sep 30, 2011 7:49 pm
Cool, makes sense, lol i actually learnt that in science this week:rolleyes:
mud_king91
Post by mud_king91 » Fri Sep 30, 2011 7:50 pm
El_Freddo wrote:I'm not sure about this, what about all those LPG converted cars? I know we never ran fuel through the carb, and this was only an issue when trying to run on fuel as the rubber O seals etc had dried out...
some times it works iv had issues with a lpg tho but either way iv got it covered
the bi carb helps with the electrolising process so basically depending on if i go dry cell or wet cell... ah screw it ill draw up a basic diagram
mud_king91
Post by mud_king91 » Fri Sep 30, 2011 8:35 pm
eh stupid computer wont let me upload ill try again later
mud_king91
Post by mud_king91 » Fri Sep 30, 2011 9:51 pm
ringing subawreck tomorrow see if i can get subaru cheap even if it,s engineless... would anyone have a cheap engine to suit an old subaru ?
Post by El_Freddo » Fri Sep 30, 2011 10:36 pm
mud_king91 wrote:ringing subawreck tomorrow see if i can get subaru cheap even if it,s engineless... would anyone have a cheap engine to suit an old subaru ?
If you want to keep it stock it'll really depend on what you get. Also the EA82 is more work to fit in the MY body shape than a SOHC EJ - this is because the EA82 is the widest engine subaru have produced AFAIK.
mud_king91
Post by mud_king91 » Sat Oct 01, 2011 9:00 am
Haha well ill keep that in mind id like a brumby but an l would be the better lab rat atm due to its storage spaces and 5 seats
Post by steptoe » Sat Oct 01, 2011 9:06 am
Has theory changed on the energy requirements to produce enough hydrogen to power a normal car engine? Only if you have discovered the secrets that went to the grave with Stanley Meyer(s)
The only units I have seen in action on a car have been enough to smooth out the idle and leave a white powdered mess under the bonnet. That little Festi died a quick death due to an L plater zipping through a give way at not so good timing. Replacement Festi now sports an 18 litre LPG tank for cheap and cheerful motoring.
BRAT EA81T were mpfi in US weren't they - stick in a wanted EA81T ad, saw one for sale recently in here?
Post by steptoe » Sat Oct 01, 2011 9:07 am
Post by steptoe » Sat Oct 01, 2011 9:08 am
