Brumby Spare Tyre
brumbee
Brumby Spare Tyre
Post by brumbee » Fri May 02, 2008 3:47 pm
I have changed to 14s mudtyres, and my new spare doesn't fit under the bonnet, at the moment it is just floating around in the back under the cover.
how has everyone else stored their spares?
was thinking of cutting a hole in the tray just behind the cab and building a cage so the tyre can sit vertical but still fit under the cover.
has this been done?
it it going to weaken the tray too much?
subybrumby
Post by subybrumby » Fri May 02, 2008 3:53 pm
Mine just lays on the back tray with jack, tools etc. What you are proposing sounds ok. Be interesting to see what others propose. I'll watch this thread.
I have a little bit of rust in that area of the tray so it would be a good project to do at the same time.
Post by El_Freddo » Fri May 02, 2008 4:01 pm
There's always a wheel carrier, may look a little funny on a ute at first but still keeps your tray area free and your cover as it is.
Some people stick them on a set of roof racks, I personally don't like that look but it may be practial to you if you use your tray area a lot.
brumbee
Post by brumbee » Fri May 02, 2008 4:06 pm
i also have some rust in the area i want to cut, so might as well improve it while i'm there
keep em coming
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sat May 03, 2008 9:07 pm
I orginally thought a rear wheel carrier on a ute would look silly but after installing one on Dwaynes Brumby it doesnt look half bad. He does have a canopy which gives it a more wagon look so without one i dont know how it would look.
The long road ahead
dwayneb
Post by dwayneb » Sun May 04, 2008 8:45 am
This is the rear bar that Suby Wan out on to mine, before the bar was fitted, the spare was under the false floor, behind the draws. Before the false floor was put in, I wpuld just lay it in there, with a bit of wire rope wound around the wheel, and tied to the tie down point inside the tray for a bit of security.
subybrumby
Post by subybrumby » Sun May 04, 2008 9:44 pm
Not what I have in mind...I'm sure its a good job. Somewhere on the forum, its says that the purgeot 505 rims are fine for a spare for the 14" wheel. We have a bloke in Toowoomba that has a paddock full of purgeots. I'll pick up a spare and work from there. I would rather the spare be outta sight really. Thanks for the photo...all ideas are appreciated. Cheers....Trevor
