4x4 or 2x4 flywheel?
esray71
Post by esray71 » Fri Mar 28, 2008 4:54 pm
Does anyone know the difference between the flywheel of the 4 wheel drive and 2 wheel drive?? I have a 94 L series wagon EA82 Carb 4x4. Had a look at the wreckers and they didn't have them marked well enough and they could not decide which one was the 4x4 flywheel. The 2 they had where different, one had a bevelled edge (45degree) and the other was a square edge (90degree). Any help would be greatly appreciated, thanks!
Post by El_Freddo » Tue Apr 01, 2008 4:16 pm
The two wheel drive flywheel uses a smaller clutch setup:
The 4wd clutch will bolt up near the outter edge of the flywheel
The 2wd clutch will be an inch or so in from the otter edge of the flywheel where it bolts up.
Hope this helps.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue Apr 01, 2008 7:58 pm
The bevelled flywheel is from an EA81 and the spare edge from the EA82 if you have a FWD clutch they run a smaller diameter clutch plate with a thicker wall on the flywheel. They also have a smaller spline (same as MY series) on the clutch plate. EA and EJ cltuch plates are the same spline.
The long road ahead
Matatak
Post by Matatak » Tue Apr 01, 2008 9:51 pm
Suby Wan Kenobi wrote:EA and EJ cltuch plates are the same spline.
Lseries and EJ..but not EA81 boxes
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
esray71
Post by esray71 » Wed Apr 02, 2008 8:51 pm
Great thanks guys!
