4x4 or 2x4 flywheel?
Does anyone know the difference between the flywheel of the 4 wheel drive and 2 wheel drive?? I have a 94 L series wagon EA82 Carb 4x4. Had a look at the wreckers and they didn't have them marked well enough and they could not decide which one was the 4x4 flywheel. The 2 they had where different, one had a bevelled edge (45degree) and the other was a square edge (90degree). Any help would be greatly appreciated, thanks!
- Suby Wan Kenobi
The bevelled flywheel is from an EA81 and the spare edge from the EA82 if you have a FWD clutch they run a smaller diameter clutch plate with a thicker wall on the flywheel. They also have a smaller spline (same as MY series) on the clutch plate. EA and EJ cltuch plates are the same spline.
The long road ahead
The long road ahead
