what box is this
dibs
what box is this
Post by dibs » Sun Mar 02, 2008 1:37 pm
today i got a gearbox .the guy said it was 5 speed and the gear knob on the floor did to .i got home and theres heaps of diference.
clutch fork on other side of center split
high low 4wd goes through back of box then to front on right side of box ( I think thats what it is )
much heavier robust box
no extention housing to speek of
tin plate on top at back
tail shaft is longer with center bearing
what bafels me is theres only 1 shifter rod on left at back and cant seam to work it through the gears
if its rite what clutch and does this one need an adaptor plate
all words of wisdom greatfully acepted
dibs
Matatak
Post by Matatak » Sun Mar 02, 2008 1:46 pm
sounds like an Lseries 5 speed DR box.
basically alot of clutches will fit.
clutch disc can be a 9inch OD Lseries or Liberty (theyre the same neway)
can be used with a 9inch MY flywheel and pressureplate or an Lseries flywheel and Pressureplate.
Lseries clutch fork and release bearing is the only way to go but
if ur running an EJ then yes it will still use the same adapter plate as a 4speed.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
brumbyrunner
Post by brumbyrunner » Sun Mar 02, 2008 6:23 pm
Throw some pics up dibs.
Is this for your Brumby?
Settlement Creek Racing
dibs
Post by dibs » Sun Mar 02, 2008 8:06 pm
yup il do it tomorrow .
then you all can tell me what is missing.and also were do you find what ratio it would be i got a dif with it so only means changing it to .
now all i need is a power rack so the other half will drive it got the pump nbracket.airs in, lift kit sitting on floor along with 14s .then thats about all till the moter dies.
dibs
Post by AlpineRaven » Sun Mar 02, 2008 10:07 pm
Can you show pictures then we would be able to recognise the box...
Post by El_Freddo » Mon Mar 03, 2008 12:56 pm
Dibs, you probably won't be able to change gears unless you're holding the support bolt in one place as you move the gear stick. The L series uses the body to support the base of the gear shifter linkage, as opposed to the EA81 4 speed that used the box as its support base.
Give that a go. I really think you've got the 5 spd EA82 box - which i think is what you're after unless you wanted a replacement 4 spd box (which would drop straight into your brumby/MY without any mods)...
No adaptor plate needed for an EA81 to the 5 spd, but will need it if EJ to 5spd (as matatak has said)...
dibs
Post by dibs » Mon Mar 03, 2008 7:35 pm
here they are i think
http://community.webshots.com/album/562668931ViVrco
see wat you think
dibs
Jack
Post by Jack » Mon Mar 03, 2008 7:44 pm
Looks like a 3 speed auto box to me.
(then again, I'm not very clever with these things)
1999 Outback (some mods)
1989 Brumby (more mods)
Post by D3V1L » Mon Mar 03, 2008 8:09 pm
looks liek an L series dual range box to me
Post by steptoe » Mon Mar 03, 2008 9:33 pm
I just won a laptop ! the one millionth viewer ! but failed to continue with signing up with all the merchandisers sites, pffft
anyone else ??
Looks just like the 3.9 ratio 4WD d/r box i bought but not yet fitted.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Mon Mar 03, 2008 9:50 pm
Definately L Dual range
The long road ahead
Post by El_Freddo » Tue Mar 04, 2008 9:28 am
Suby Wan Kenobi wrote:Definately L Dual range
No doubt about that ;)
steptoe wrote:I just won a laptop ! the one millionth viewer ! but failed to continue with signing up with all the merchandisers sites, pffft
anyone else ??
I was too... those things should be deemed as false advertising. I didn't go though with it either...
