what box is this
what box is this
today i got a gearbox .the guy said it was 5 speed and the gear knob on the floor did to .i got home and theres heaps of diference.
clutch fork on other side of center split
high low 4wd goes through back of box then to front on right side of box ( I think thats what it is )
much heavier robust box
no extention housing to speek of
tin plate on top at back
tail shaft is longer with center bearing
what bafels me is theres only 1 shifter rod on left at back and cant seam to work it through the gears
if its rite what clutch and does this one need an adaptor plate
all words of wisdom greatfully acepted
dibs
dibs
sounds like an Lseries 5 speed DR box.
basically alot of clutches will fit.
clutch disc can be a 9inch OD Lseries or Liberty (theyre the same neway)
can be used with a 9inch MY flywheel and pressureplate or an Lseries flywheel and Pressureplate.
Lseries clutch fork and release bearing is the only way to go but
if ur running an EJ then yes it will still use the same adapter plate as a 4speed.
Wagon is no longer....
- brumbyrunner
yup il do it tomorrow .
then you all can tell me what is missing.and also were do you find what ratio it would be i got a dif with it so only means changing it to .
now all i need is a power rack so the other half will drive it got the pump nbracket.airs in, lift kit sitting on floor along with 14s .then thats about all till the moter dies.
dibs
dibs
Can you show pictures then we would be able to recognise the box...
Dibs, you probably won't be able to change gears unless you're holding the support bolt in one place as you move the gear stick. The L series uses the body to support the base of the gear shifter linkage, as opposed to the EA81 4 speed that used the box as its support base.
Give that a go. I really think you've got the 5 spd EA82 box - which i think is what you're after unless you wanted a replacement 4 spd box (which would drop straight into your brumby/MY without any mods)...
No adaptor plate needed for an EA81 to the 5 spd, but will need it if EJ to 5spd (as matatak has said)...
looks liek an L series dual range box to me
- Suby Wan Kenobi
No doubt about thatSuby Wan Kenobi wrote:Definately L Dual range
I was too... those things should be deemed as false advertising. I didn't go though with it either...steptoe wrote:I just won a laptop ! the one millionth viewer ! but failed to continue with signing up with all the merchandisers sites, pffft
anyone else ??
