Strange bogg issue SPFI EA82?
The Loyale
Post by The Loyale » Mon Feb 18, 2008 2:47 pm
Alright, This has been going on for a few months now.
Lets say you go to the store, And come out 30-45min later, Start the car, Let it ideal for a 1 min or so. Then put it in drive, Take off out of the parking lot and get to the road. Then when you feed the gas to get going, It kinda feels like it boggs so you push the pedel a little harder and then the bogg go's away and the RPMs come up and you're like flying down the road (1/4 to 1/2 Throttle)
Could that be from a dirty IAC? Or what? It does't do it when you drive, Only after you go somewhere, Let it sit. Come out, Putts thru the parking lot and get to the road, Go to take off and it won't really go, And then all of a sudden it will!? Any ideas guys?
Tom
'92 Loyale - Safariwagon (Under Restoration)
130,000
'92 Toyota Landcruiser - Safariwagon-II "Nimble as an Ox!"
181,000
timmo
Post by timmo » Mon Feb 18, 2008 4:17 pm
no SPFIs in australia so you might not get much help but an obvious thing would be to replace the fuel filter if you havnt already
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
dfoyl
Post by dfoyl » Mon Feb 18, 2008 6:01 pm
>>no SPFIs in aus
Speak for yourself - I've got a full SPFI kit about to go on to my EA81 :)
From USMB info, it sounds like a MAF issue.
Here's one link: http://www.ultimatesubaru.org/forum/sho ... spfi+issue
Or this:
Just search on "SPFI issue" and there's handfuls of info...
Dean.
timmo
Post by timmo » Mon Feb 18, 2008 7:41 pm
dfoyl wrote:>>no SPFIs in aus
lucky you....
GU Patrol Ute
Honda XR400R
Post by Subafury » Mon Feb 18, 2008 10:12 pm
clogged injectors maybe. maf and something fuel related i think
Post by steptoe » Mon Feb 18, 2008 11:47 pm
fuel presure gauge may tell a story here
Matatak
Post by Matatak » Mon Feb 18, 2008 11:55 pm
the obvious things to look at would be.
Spark plugs
plug leads
injector.
fuel filter/s (for clogging)
fuel pressure
Throttle body (ie clean it out)
Maf (clean it if u have even got one lol)
and then look at other stuff if it dont fix it.
maybe its an auto issue (most likely not and will be an easy fix)
The Loyale wrote:Then when you feed the gas to get going, It kinda feels like it boggs so you push the pedel a little harder and then the bogg go's away and the RPMs come up and you're like flying down the road (1/4 to 1/2 Throttle)
i like this :) uve got an EA82 and ur saying at half throttle that you start flying down the road :p. haha
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
The Loyale
Post by The Loyale » Tue Feb 19, 2008 8:17 am
Alright, Yeah I'm on USMB too, But I figured I would ask you guys first..
I did change the fuel filter, Plugs (NGK) Wires (NGK) and I cleaned the MAF. And the throttle body is clean too.
Matatak, What I mean by "Flying down the road" is that at like 1/4 to 1/2 then it like kicks in and you get all you're power back. But it only does it once after it's been sitting in a packing lot. Other then that it's always fine.. But I'll check the links out and see what I find.
I know the fuel psi is good, Because if I driving and disside to go from 30mph to 50mph it will go... So I dunno, But I'll check it all out.
Thanks guys!
130,000
181,000
Matatak
Post by Matatak » Tue Feb 19, 2008 9:03 pm
The Loyale wrote: Matatak, What I mean by "Flying down the road" is that at like 1/4 to 1/2 then it like kicks in and you get all you're power back. But it only does it once after it's been sitting in a packing lot. Other then that it's always fine.. But I'll check the links out and see what I find.
Haha tis all good i jsut found sayin it that way made it funny :p
back to ur problem.
i reckon TPS
The Loyale
Post by The Loyale » Sun Feb 24, 2008 5:52 pm
Matatak wrote:Haha tis all good i jsut found sayin it that way made it funny :p
back to ur problem.
i reckon TPS
Haha, Yeah it did sound funny! :p
What is TPS, Maybe I'm just slow Lol....;)
130,000
181,000
littlewhiteute
Post by littlewhiteute » Sun Feb 24, 2008 6:19 pm
The Loyale wrote:Haha, Yeah it did sound funny! :p
TPS - Throttle Position Sensor ;)
I'd be looking at the coolant temp sensor, or possibly dirty injectors.
Gary ;)
Post by Gannon » Sun Feb 24, 2008 8:40 pm
dfoyl wrote: I've got a full SPFI kit about to go on to my EA81 :)
Sorry to hijack, but hows that coming along?
Post by El_Freddo » Fri Mar 21, 2008 10:29 am
So what's happening Loyale?
Got it sorted?
subybrumby
Post by subybrumby » Fri Mar 21, 2008 7:45 pm
Hoping not to hi-jack this thread but:-
Bought an EA82turbo brumby and drove back from Brisbane. Put BP unltimate in it and it stopped. I changed the fuel filter and now it has a flat spot. When you hit the throttle there a definite flat spot then she picks up. It smells rich but there is a definte lag and fallter coming off idle. If she's idling and the air con comes on, it dies right off and nearly snuffs it. What should I be looking at??
Any thoughts???
