L Series Brake master cyl fits in MY ??
I know:
1.0 others have improved their MY brakes by jamming in an L series booster
2.0 others have said an L master won't fit MY because of the number of outlets , 4 in an L and 2 in an MY
Is it not just that the four way junction is in the master in an L and on the body in an MY?
It LOOKS to me that if one was to hook up the MY pipes to the two underside outlets on an L (one is front and one is rear) and find a way to block off the side outlets (say with the bleed nipples from the MY) that it would be all hunky dory - dunno if it is all going to be BETTER if it is safe to do so in the first place ?
your comments and suggestions, esp if you have tried this !!
ta,
ta,
Yeah i put a lib booster and lib master cylinder in my car. With mine i had to make sure the new cylinder had outlets at the bottom and i blocked off the other 2 outlets with fittings from a local hydrolics shop.
Dave
Dave
but like Subarino says. local hydrualics shop. and i to have got a Liberty Booster and M/Cylinder (but also rear discs)steptoe wrote:I know:
Or a Liberty Booster and M/Cylinder
So easy to work with lol
Pretty Much
Bleed nipples wont work. the Bleed nipples have a convex and when they need a Flared/Concave end
ta,
Wagon is no longer....
