L Series Brake master cyl fits in MY ??
Post by steptoe » Fri Jan 11, 2008 12:47 pm
I know:
1.0 others have improved their MY brakes by jamming in an L series booster
2.0 others have said an L master won't fit MY because of the number of outlets , 4 in an L and 2 in an MY
Is it not just that the four way junction is in the master in an L and on the body in an MY?
It LOOKS to me that if one was to hook up the MY pipes to the two underside outlets on an L (one is front and one is rear) and find a way to block off the side outlets (say with the bleed nipples from the MY) that it would be all hunky dory - dunno if it is all going to be BETTER if it is safe to do so in the first place ?
your comments and suggestions, esp if you have tried this !!
ta,
90brumby
Post by 90brumby » Fri Jan 11, 2008 6:38 pm
i no a couple of WA guys have put lib boosters and master cyls in there MY mkes the pedals betta apperently
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
SuBaRiNo
Post by SuBaRiNo » Fri Jan 11, 2008 6:46 pm
Yeah i put a lib booster and lib master cylinder in my car. With mine i had to make sure the new cylinder had outlets at the bottom and i blocked off the other 2 outlets with fittings from a local hydrolics shop.
Dave
Matatak
Post by Matatak » Sun Jan 13, 2008 9:42 pm
steptoe wrote:I know:
Or a Liberty Booster and M/Cylinder
So easy to work with lol
Pretty Much
Bleed nipples wont work. the Bleed nipples have a convex and when they need a Flared/Concave end
ta,
but like Subarino says. local hydrualics shop. and i to have got a Liberty Booster and M/Cylinder (but also rear discs)
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by steptoe » Sun Jan 13, 2008 11:43 pm
thanks guys, might have to give this a try one day and get the plugs sorted before install. I got the L bits, might as well try them first. Then the rear disc set up - if I can bear reducing me GLTA to parts that is :(
