ea82 mpfi cracked head
i got a cracked head on my mpfi engine. now i'm no mechanic so i don't really understand what it means. also what would it take to replace it? any help would be greatly appriciated. i'm curently in ormond vic but i'm also in jeparit.
cheers all
cheers all
1989 L touring wagon auto (project)
1969 beetle street car (project)
= me:)
= me:)
where is the crack?
If its between the valve seats you should be ok.
If you are no mechanic then a head removal/reinstallation is not something you will want to attempt yourself. It will need to have the offending head taken off the motor and fixed at a head repair place. Depending on where the crack is and the severity they can quite often weld it up and pressure test the head.
