EJ22 P/Steering Pump
has ne1 pulled one apart?
im jsut curious as to whats actually inside em. ive been todl there isnt much
1 Gasket, 2 O-Rings,1 or 2 Seals and a Bearing. maybe a bit more
ive also heard i can get all of em which im gonna be tryna pull mine apart and reseal it as i dun wanna be payin 400 for another one. thats just a ripoff IMHO.
any of u WA boys have one ud be willing to give away to me? screwed/leaking wteva
Wagon is no longer....
For starters - whats wrong with it?
For these EJ's P/S pump always leaks from the bottom O ring.
Yep fair enough... I am not sure if there is an PDF manual floating online that would help ya?Matatak wrote:lol liek i said im gonna pull it apart and reseal it. coz it leaks. pretty badly really.
and instead of doin one O-Ring id rather do it all including a new bearing.
Brendon has a completely buggered one I beleive...
Do they get that hot?seagull wrote:I have one that I removed from my front cut ( round tank type )
$120.00
There has been many guys that cook them going around & around & around & around & around & around & around & around .
One of the best things you can do is fit an oil cooler to it , with heavy sand work they over heat .
i got about 6 busted ones in the shed that proves they get that hot. I think some of my problem was due to problems with my steering linkages though.
I had an oil cooler and have since removed it when i grew out of doing donuts and fixed the linkages.
There is a reason they say not to hold it in full look for more than a few seconds.
Dave
Dave
pish posh. go hard or go home!
i got one in bits if ya wanna have a gander matto
Hunter S. Thompson
Hunter S. Thompson
hmmmm wt was ur cut and how many K's??seagull wrote:I have one that I removed from my front cut ( round tank type )
$120.00
throw in the lines and i might eb interested
Im sure there is somehting in there about not doing Donuts too.
Dave
Dave
