costly little bugger...EA82 throttle body hose...
Post by steptoe » Sun Oct 07, 2007 12:22 pm
just when i thought Cheap Grief was ready for rego, I find green stuff seeping from somewhere. I am underneath and a pressure test helped find the only hoses I have not replaced are the culprit (figures). The little 7.5mm id hoses feeding to and from the throttle body. ONe is seeping, just. Go genuine. one is 14 bucks the other about 45 ! I was gonna order two 14 hoses and see if i could make it fit. The parts man suggested the extra money would probably be worth it - save stuffing around.
So when i get the two hoses i find i reckn seeing as though they are rubber, the same id, od and config the cheaper one will fit where the dearer one has to go.
TIP order two 80760752 hoses and make it fit where 807607062 goes. The only diff is a mild bend - and save a few bucks.
Post by Gannon » Sun Oct 07, 2007 6:55 pm
I had the same problem when i rebuilt my motor.
I think I just used some spair fuel hose.
Now the one that goes from the top/centre of the block to the thermostat is dripping green coolant, have you seen how hard it is to get to?
Post by steptoe » Mon Oct 08, 2007 10:35 pm
um , that is the one that needs inlet manifold removal ain't it?
I did do that one at about $14, even the clamp is tight clearance
ooh, feel sorry for you
Post by Gannon » Tue Oct 09, 2007 6:42 am
Looks like it, but i hope i can do it without removing the manifold.
The fact that i dont have power steering might work in my favour
Post by El_Freddo » Tue Oct 09, 2007 10:50 am
I've done this one without taking the manifold off. I forgot to put in on when in was building the motor :sad:
After a month or two, re-check all your hoses, i've found a few of mine weeping a little.
Good luck.
Post by steptoe » Wed Oct 10, 2007 12:32 am
with any luck i will be extracting engine in three months to fit into a Brumby, so will keep an eye in things then.....
