Lift Kit
Gardiner
Lift Kit
Post by Gardiner » Sun Mar 25, 2007 7:56 am
Hey just got my lift kit but have trouble gettin into 2nd, 4th and reverserve without hitting console. When take console off hits bloody high low gear lever.
What do i do im crunchin all my gears?
Gardiner
Lift kit
Post by Gardiner » Sun Mar 25, 2007 12:13 pm
I assume others must have had this problem as soon as they lift their suba's. Is it because i have not installed my larger tyres and rims yet???
How hard is it to fix this problem help please!!!
Brumby Boy
Post by Brumby Boy » Sun Mar 25, 2007 12:17 pm
Check your gear shift bushes and gear box mounts, that seams to be the main cause of these problems, But on my ute the lever hits the dash and the 4wd lever sits up a bit
RIP 1992 Brumby
90brumby
Post by 90brumby » Sun Mar 25, 2007 3:12 pm
how big is ur lift kit as i have just fitted a 4inch and have had to heat up and bend the gear shifter to allow all the gears 2 be selectered
PHATnob
Post by PHATnob » Thu Mar 29, 2007 10:05 pm
I had same trouble when I first lifted my wagon by 2", and it seems to be by moving the gearbox from the body, the alignment of the shifter linkages was altered to a point where it ran into the shell of the vehicle/to the dash/other places. (It used to suck changing to fifth and having your music stop whilst your favorite CD is spat out of the head unit because you accidentally pressed eject..)
What Gearbox/Shifter set up have you installed. EA81 or 82?
Make certain that the securing pin is not loose on the shifter throw, or it is not worn, as it can cause the shaft to not be moved far enough. This can cause reverse and sometimes other gears to 'pop' out under load.
Not an expert, but maybe something to check.
Cheers.
