water pump
water pump
just wondering what is involved to get ur water pump mine has shat it self and trying to get it out seems like a bit of a struggle any info would be great cheers
- Brumby Boy
What type of car is this on? ea 81, ea82, ej?
RIP 1992 Brumby
RIP 1992 Brumby
Hey riby,
You'll have to remove the Air con and alternator. These can come out as one unit (put in battery bay - don't take off the air con hoses), just gotta find all the bolts, there's one under the AC unit that has a slotted hole that doesn't need to come all the way out, one under the alternator, one on the inlet manifold and the belt runner for the AC belt is also one of the holding bolts.
Your power steering if you have it will have to come out.
Best to do all this without the radiator in, just avoids damage and gives you more room.
Hope this helps
Hope this helps
